Results 1 to 10 of 13
August 11th, 2022 05:10 PM #1
Can anyone recommend a repair shop around Taguig or Pasig?
Ayaw magbukas ng trunk ko, want to have the cable checked.
- Sep 2016
- 99
August 11th, 2022 10:28 PM #2[QUOTE=ice15;3316695]Can anyone recommend a repair shop around Taguig or Pasig?
up natin sir
- 54,205
August 12th, 2022 09:29 AM #4
- 54,205
August 12th, 2022 10:41 AM #6[QUOTE=ice15;3316757]sometimes,
there is nothing wrong with the cable.
but the rubber strip lining the rear opening somehow gets stuck to the metal.
one gets the impression that the cable isn't working, when actually, it is. but the rear hood does not pop open.
what i do, is to pull that release thingee, then get out and "aggressively nudge" the rear hood open. after a few tries, it opens up naman.
good luck.Last edited by dr. d; August 12th, 2022 at 10:50 AM.
August 12th, 2022 10:49 AM #7
I was initially thinking na I can live using the remote until my next PMS this Nov...
kaso the remote pala does not work when the engine is running
- 54,205
August 12th, 2022 10:59 AM #8errr,
i do not understand...
if your car is still under warranty,
i believe this "malfunction" is warranty-able.
i'd go to the casa asap.
if the problem occurs often enough in their cars, the knowleedgeable mekaniko might be able to fix it, without your having to go to queue. the veritable "konting tadjak"...
August 12th, 2022 01:23 PM #9
August 12th, 2022 02:35 PM #10
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
