Results 11 to 20 of 35
June 19th, 2006 03:39 PM #11kung nasa iyo pa ang invoice/joborder ng rapide, balikan mo sila at magwala ka doon(labas mo sama ng loob mo, murahin mo silang lahat), insist mo na ayusin nila iyun kapalpakan na nagawa nila... hindi ko alam pero usually may implied warranty sa job rendered sa mga ganoon na service?
June 19th, 2006 03:56 PM #12
Originally Posted by chuaed
June 19th, 2006 04:06 PM #13
Originally Posted by ghosthunter
Originally Posted by alwayz_yummy
June 19th, 2006 04:48 PM #15
Originally Posted by nascar
Not sure if they can do the job but you can try asking:
SpeedyFix
tel: 723-7625
cel: 0917-534-7636
June 19th, 2006 04:59 PM #16
well, another solution is to just use that same type of delco plugs if wala namang issue sa takbo.
- May 2005
- 30
June 19th, 2006 05:36 PM #17Experience the same thing with Rapide. A year ago nagpatune up ako sa rapide, had no choice kasi sila lang open na shop ng sunday and i need to have my ride checked kasi byahe ako ng Monday morning. They used AC Delco spark plugs din. Wala naman naging problem until my next tune up. Nun nagpatune up na ko ulit this time with my suking mechanic, nun tinatangal na yun spark plugs nagtaka yun mechanic dahil pagpihit nya nun isang spark plug eh maluwag agad. Yun pala naghiwalay yun ceramic part ng spark plugs at yun metal thread. In short naiwan yun metal part na may thread na nakakabit pa. They removed the cylinder cover to access yun naiwan part pero di pa din maabot. So they recommend na ipamachine shop para matanggal. Pero nagtry pa din sila na dukutin using vise grip pero di makapasok ng todo yun vise grip. Good thing may pliers ako na medyo maliit yun body and it was able to get a grip on the remaining exposed metal part nun spark plugs at na unscrew. Na save ako from having it machined shop, the damage was slight scratches sa may spark plug hole then checked and removed yun mga metal shavings na naiwan from the spark plugs. Then ok na ulit ride ko. Di na ko bumalik sa rapide ulit and never will i use AC Delco again.
June 19th, 2006 05:50 PM #18
Originally Posted by theveed
Thanks.
June 19th, 2006 06:30 PM #19
Originally Posted by TFX
.. well, better not go back there again..ever!!
June 19th, 2006 11:08 PM #20
They also force fit AC Delco oil filters in case you want a matching set. Rapide, naaawa ako sa mga cliente nila.
Any reviews for the Triton GLX 4WD 6MT? Siya ata pinakasulit na middle 4WD variant. Price range...
2022 Mitsubishi Strada/Triton (6th Generation)
