Results 1 to 2 of 2
- Jun 2004
- 1,311
December 7th, 2005 02:27 AM #1The D4 indicator is blinking on my 95 Accord. While I was driving on the expressway the speedometer also suddenly read 0 instead of the supposed 80 kph. Later on though the speedometer was working again, all the gears seem to work fine also.
The ATF level is ok, also it smells sweet, which is normal. I may also try to check the error code. But in the meantine has anyone else experienced this kind of problem? What do I need to fix or check?
I suspect that the problem may be with the speed sensor or speedometer cable being loose... Can I fix this myself?Last edited by chris_d; December 7th, 2005 at 02:45 AM.
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 9th, 2005 10:05 AM #2speed sensor is either busted or about to conk out na. replace it nalang.
The Yokohama BluEarths notoriously break down as you use them. I guess something in their...
Finding the Best Tire for You
