hi tulong naman for an idea or solution if you have encounter this kind of problem...
when i engage the 4LO or 4HI then run for a couple of meters (maybe 7 or more for 4HI) parang nagbrake then i can not return the 4wd lever to 2HI kahit na FREE na yung HUB LOCK, i have to reverse the pick up para marelease ang LEVER to 2HI...
akala ko nung una, nagstuck up yung brake pad kasi di mo man lang maitulak in NEUTRAL, nung ijack-up ko na at icheck if my prob sa brake umikot ung gulong reverse, yun pwede na maengage ang 4wd lever to 2HI and matulak na ang pick up.. any ideas why?
di ko na magamit ang 4wd pag fully loaded kasi ang hirap na itakbo after a couple of meters.... differential of front and rear are 7 45 teeth(match)
ano kaya problema nito?
salamat sa mag iinput...
