Quote Originally Posted by afrasay View Post
radiazone,
you can use your 4low on a pave road provided you don't engage your front hubs. this would multiple your torque increasing your pulling power especially when going uphill. I do this when going thru deep flooded streets like in the sampaloc area. This way I don't need to rev the engine (prevent splashes to the engine) that much. let me add that you can use your 4hi and 4low on paved roads provided you drive straight with minimal turns.
thanks for that info master afrasay kala ko sira na transmission ko...
di ko na lang sasabihan yung mekaniko na parang magbrake ung sasakyan pag naka 4LO in a pave or asphalt road, wala rin pala siya idea why it brake na hindi ka nagaaply ng brake... atleast nalinis yung loob nang transfer case kasi dami ng grinding particles sa OIL drain plug galing sa wear out ng reverse gear....
