Results 1 to 9 of 9
December 1st, 2003 09:56 AM #1
:bald: hey peeps help naman
car is a 97 city lx m/t
manual steering lang po sya.
recently may tumutunog na "clok-clok" sa ilalim
kapag dumadaan sa lubak-lubak.
replaced rack-ends, tie-rod ends, both front shocks na
the rack ends & tie-rod ends are OEM, but installed
outside the casa. the shocks are kyb and also installed outside the casa..
when i had it diagnosed, binaba pa yung buong
rack & pinion assembly para talagang makita ang problema..mechanic said sira na daw ang pinion gear..
hindi naman daw siya bungi...sira daw yung bearing...sabi rin niya hindi nakakabili ng yun lang..bibilhin mo buong assembly na..
:whoa:
pwede p b tong i-repair o bumili nito?
ang mahal kasi ng buong assembly.hindi kaya ng budget.
December 1st, 2003 10:05 AM #2
Did they also happen to check the bushings? Shock absorber bushings, anti-sway bar bushings and etc.
December 1st, 2003 08:56 PM #3
hmmm. as i can remember, hindi yata. pero one time when i brought it to honda to have it repaired.. it said in the receipt: "lubricated steering preload" after that the noise was gone. then after a few weeks ayan na naman siya.
- Apr 2003
- 526
December 1st, 2003 09:43 PM #4do bearings go clok-clok? probably one of your bushings.
where did you have it diagnosed? casa ba yan?
December 2nd, 2003 11:16 AM #5
Sa Casa yon, then i went to Rapide and also to Servitek to get a second opinion..they all seem to point to that part..
what i want to know is, can i buy that part alone? (pinion gear) or i have to buy the whole rack & pinion assembly.
December 2nd, 2003 12:55 PM #6
Time to bring it to cousin Ferdie...
_______________________________________
December 2nd, 2003 09:22 PM #7
Hindi kaya CV joint?
December 3rd, 2003 11:43 AM #8
forgot to mention....napaltan ko na rin pala CV joints...pero sa outer lang..alam ko iba ang tunog pag CV joint ang sira eh..tsaka hindi siya tumutunog pag nalulubak..tama ba?
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 15th, 2003 12:16 PM #9try and bring it to the shop. we can do our diagnosis of the problem and give you an estimateÜ
