Results 1 to 11 of 11
    Mar 2003
    Sabi nila it will gain 27-35hp pag nag palit ka ng pulley? (para dun sa MB ko ito..yung pulley ng supercharger).
    Meron din yung Powerchip.(will accelerate quicker)..lalo na sa A/T ..kaya lang padadala pa raw sa Singapore yung computer box..(matrabaho at abala).
    Tanong ko lang...malaking pagbabago na ba sa performance ng kotse yung + 27hp-35hp? ....Safe kaya ito?
    eto yung set ng pulley:
    - 7" Crankshaft overdrive pulley
    - Aluminum water pump pulley
    - Aluminum alternator pulley
    - Aluminum power steering pulley
    - Two (2) belt tensioners w/ belt
    - Windshield washer reservoir w/ hose fitting
    pic:
    Mar 2003
    underdrive pulley. ganun kalaki yung gain? ang alam ko, by changing the pulley, it will use less energy to spin the accesory such pulley is connected to. i've read before in a magazine that there's really no hp gain by changing the pulley alone. furthermore, sa high speed ang pakinabang talaga ng underdrive pulley, when the pulley is already in motion kasi it requires less energy nga. pero pag sa stop and go traffic, especially kung connected sa alternator, the opposite is true. parang riding a bicycle uphill ang illustration nyan. by changing to a smaller sprocket, the amount of effort to push the pedal is reduced. effect: you don't move as fast , but it is easier t pedal uphill. but when this is applied to an engine already in full song, (acceptable speed and rpm na) turning the accesory won't be as hard as using a stock pulley =)
    Mar 2003
    pareng mike...Di ko rin kasi masyado ma-gets eh..:confused:
    eto yung link:
    http://www.kleemann.dk/site/Main/tun...erformancekits
    Mar 2003
    kala ko nagkamali ka lang sa pulley na overdrive kaya sinabi ko na dapat underdrive. di kaya parang nag-even out lang yung pulleys na gagamitin? since nilakihan nila yung crankshaft pulley, i guess some other pulleys would be smaller now even if the serpentine belt would be changed. i've been reading kasi sa mga magazines puro underdrive pulleys pero this is the first time i've seen bigger pulleys naman ang gagamitin. let's just wait for other inputs pareng henry. maraming experts pa naman ang makakabasa nitong thread =)
    changing the pulley to the supercharger to make it turn slightly faster is fine. This will produce slightly higher HP due to higher pressure from the supercharger.
    Nov 2004
    I did this mod myself on which I installed the RE "Power Pulleys". It is the same as of the UUC "Under Pulley". The pulleys are a bit larger in diameter than the OEM and made of aluminum 6061-T6 and treated with anodize coating and therefore lighter. Actually it only gained about 5 to 10 HP range to your engine power especially at higher rev.
    Mar 2003
    Sir, JC
    wala ka ng ginalaw/upgrade "chip" sa computer box ng bimmer?
    Nov 2004
    Originally posted by hens
    Sir, JC
    Wala, Sir... It's a straight forward swap. You don't need to re-program the ECU. :cool:
    if hens has a supercharger ("kompressor") engine he will get far more than the 5 hp you get from an n/a engine (i.e. your bimmer). it is actually the s/c pulley (which controls boost pressure) that's being changed and not the crankshaft pulley (which uses engine power to run accessories - the "underdrive" pulley takes less power from the engine at the expense of a little less power for the accessories)
    it's a great source of 30+ extra hp and as long as the pressure increase is not too large, it should have no serious effects on engine reliability/longevity.
    kleeman's prices are ridiculous though for what is essentially a pulley, ecu upgrade and filter (tama ba?)
    uyy...mukang me bago ka na namang upgrade ser hens.....
    Mar 2003
    Hmm...medyo naintindihan ko na yung pulley na yan..(problema na lang kung kaya ikabit ng CASA yang pulley or hindi..Yung bumper ko buong araw ikinabit at nag-pa Overtime pa ako..8AM-9:30PM bago na tapos..)...Anyway, Salamas preng M54 at sa ibang nag-reply.
    re: Kleemann's ..tama ka M54..kung sa Brabus..tutulo sipon mo sa mahal .pero yung Kleemann...duduguin ka sa presyo...
    5Speed,
    matagal pa yan..hehehe (pagiipunan pa).
alloy pulley?
