Results 11 to 19 of 19
May 31st, 2015 04:18 AM #11
May 31st, 2015 08:08 AM #12
Para sa dumi yan, especially pag nasa lugar na mabuhangin. Sisingit yung buhangin sa wiper at pag ginamit mo then gasgas ang windshield mo. You may not see the consequence immediately but definitely it builds up until it becomes very noticeable. Minsan mabibigla ka na lang kasi umuulan at makita mo may guhit na ng water sa windshield kahit bago pa ang wiper blades mo.
As for the spring getting stretched, kalokohan yan. Para namang hindi nagaral ng engineering yung nag design ng wiper ano? Lahat ng springs may elastic limit. Ang bobo naman nung design engineer kung nagdesign siya ng wiper na ma-exeed yung elastic limit nung spring kung iangat mo lang yung arm. I am sure the spring will not even come close to its elastic limit when the wiper arm is raised. At alam na alam naman na iaangat mo ang arm pag naglilinis ng kotse o kung magpapalit ng wiper blade. More than 100 years na gumagawa ng kotse alam na nila yan.
May 31st, 2015 08:34 AM #13
I agree with yebo on the springs, di naman mabilis masira ang springs ng wiper arm, I only replace the blades on my 15 year old ride, never the springs because they're A-Okay.
May 31st, 2015 08:58 AM #14
Pag maalikabok, either pagpagan ko ng duster at pitikin ang wiper blades sa salamin para mahulog ang mga dumi, o kung galing sa ulan o tilamsik, yung washer naman. Masagana sa tubig hanggang mawala ang putik.
Hindi pa rin dahilan magtaas ng arm. Ginagawa ko lang yan kung magpap alt ng blade. Ni wala nga yan sa manual na magtaas habang naka park.
Kayo din, basta nasabi ko na marupok na metal lang yung pivot sa ilaim nyang wiper arm. Wag lang maaksidenteng mabungi yun, kundi lipad mga 7 mil ninyo
May 31st, 2015 09:23 AM #15
Like any rubber component, wiper blades are wear and tear consumable items that will eventually age whether you use it or not. It won't matter if it's lifted or left kissing the windshield, it wil still age. If it's under the sun a lot, it will age faster. It does have UV inhibitors but they too, expire eventually.
If you see water streaks when you use the wipers, chances are, they just need to be changed.
Wiper blades are cheap to replace... and you only have to replace them every 2-3 years for best performance.Last edited by oj88; May 31st, 2015 at 09:25 AM.
- May 2015
- 40
May 31st, 2015 09:57 AM #16tinataas lang yan pag winter kasi nagpifreeze yan with the windshield. dyan siguro nakuha yong idea nong mga nagtataas ng arm. kaya lang wala naman tayong winter kaya useless ang ginagawa nila. napakamura ng wiper blade compare sa masisave mo kung totoo ngang naprolong ang life sa pagtaas ng arm plus the hassle of doing it everytime. add the fact na hindi designed ang arm na nakataas for long time. baka in the end mas napamahal ka pa kesa makatipid.
- Sep 2013
- 505
June 7th, 2015 06:52 PM #17IMO those wiper stands are silly creations. just creates an annoying slap on your windshield everytime you use your wipers, or when the wipers decide to deploy on their own. hee hee
even promotes rusting on the wiper arm where you install them.
BTT: i pull away the wipers from the windshield when the vehicle is parked for a while here at home. only because it becomes a dust collector.
June 8th, 2015 12:55 AM #18
Merun na nabibili wiper stand ata tawag. Ndi mo na kailangan itaas un wiper. Nakapatong un wiper sa stand para ndi mainitan kahit ndi nakataas.
June 8th, 2015 09:27 AM #19
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
