Results 1 to 7 of 7
    I only experience this during cold starts in the morning.
    I notice that pag engage ko sa reverse after initial startup, biglang magrerev ang engine causing it to "thud" reverse.
    I don't experience it after the engine is warmed up specially when AC is on.
    Ano kaya ang problem? Sabi nila yung "thud" experience might be due to worn out engine support?]
    Car btw is an Altis '03 AT
    TIA.
    Aug 2007
    I also experience this with our 2000 Corolla.
    Mag thud siya every morning when backing out the garage.
    I think the reason for this is the car operates at a higher RPM when engine is cold until it heats up to the normal operating temperature.
    What I usually do is shift it to D first then to R.
    Nov 2003
    yup, probably nga cause mataas yung idle when you just turn on the engine.
    Thanks Augustus, Speedyfix. Problem is I don't experience this with our other corolla '02 model.
    *Augustus, I might try the Drive then Reverse technique.
    *Speedy: Might have it checked na din since nearing my 5tkms PMS..isabay ko na.
    Tnx.
    Jun 2007
    wow ako din ganto with my lancer 97 A/T specially pag umaga talaga pero tuwing umaga lang ito nangyayari, pero ako sa "D" ko engage never tried pa sa "R" always park my car pa reverse e
    *Djerms update po ha pagkacheck up niyo baka makatulong narin
    Feb 2006
    i experience the high rev but no 'thud', medyo slow lang mag-engage yung transmission. maybe the fluid hasn't filled the converter yet?
    Nov 2003
    no problem
Problem with AT "reverse"
