Since this is an ongoing situation, i chose to continue with this thread...
Days ago i checked my clutch fluid and the level was down a bit, as expected/anticipated, i found a leak down by the clutch pedal so i got myself the master and secondary repair kits...after replacing and bleeding, everything seemed ok but the next day i noticed, pedal was very soft and did not push back up as quickly when i released it...did not have any problem with shifting though...as i drove, after around 30mins, i noticed the pedal became stiffer and higher (to the point that i can even shift gears by just pressing the pedal by almost an inch or so)...basta ang tigas. so it thought it had something to do witht the push rod, needing adjustment...
and so nag bleed ulit kami to make sure at adjust push rod...next day came and i had exactly the same problem...had the 2ndary repair kit replaced with OEM one and still the same...now i would like to get some ideas po, baka may nakakaalam or maybe has encountered this problem already...may kinalaman kaya sa release bearing ito? or baka yung clutch master assembly na including the housing? basta sa umaga ang lambot ng clutch and when you press it all the way down, konteng release lang eh kakagat agad, tapos pagtagal eh halos bitawan mo na ang clutch bago kumagat.
