You must lubricate the regulator, window tracks and the plastic spool and on both side that support the window(mounting plate) periodically use a High Temp Urea Grease. Lack of lubrication causes the spool to bind and make popping noise while the window is raised or lowered and that put too much stress on the cable that lead to break prematurely.
