Page 15 of 22 FirstFirst ... 5111213141516171819 ... LastLast
Results 141 to 150 of 217
    ano ba ang problema sa unang pasak kung wala naman singaw?
    chineck naman yan nilagyan ng tubig wala bubbles
    buong holiday season ung gulong ang iniisip what a way to spend the holidays haha
    Apr 2016
    #142
    I go on long distance trip to Baguio kasi for example. Ayaw ko mag slip yun plug in the middle of Zigzag late at night. Paano ka maka change tire sa zigzag going uphill to Baguio. Remember wala talaga rubber cement nalagay sa original kasi wala sila stock ng rugby and need pa ako wait 20 minutes while they buy at hardware. And ATF (Automatic Transmission Fluid) was used as lubricant.
    In the video you can hear the technician defending the string plugs have built in adhesive na kasi daw sticky. I hold it pero hindi naman adhesive yun. I showed the box para can see feedback kung meron string plugs na meron built in adhesive.
    And he said in 2nd video na purpose ng rubber cement is for lubrication para mabilis ma slip, that's why substitute nila using ATF. I think both are wrong reasons.
    My concern now is yun person who will buy my used tire. The hole is made bigger na. Perhaps bigger than original reamer? Kaya thinking if it's safe for him.
    Also mag loan pa ako to buy 30,000 pesos of 4 new tires. When wala ka budget, every little thing counts. Victim ako nag pandamic and Omicron is affect it badly na talaga.
    #143
    Hinde pa rin safe yun second pasak, paulit mo ulit.
    Rugby ginamit eh hinde din dumikit dahil dapat pinapatuyo muna ng 15 minutes+ bago pinasok.
    #144
    Lahat ng repairs sa gulong, kahit gaano kagaling at katino nung gumawa, may chance na bumigay. Ang bagay lang sayo is to get a new tire everytime mabutasan ka ng gulong.
    Signature
    Feb 2014
    #145
    rubber cement for tire repair isn't rugby
    btw meron glueless tire plugs but they're rare. meron ako nabili sa taiwan. coz those little tubes of rubber cement tend to evaporate so they're empty when you need them
    Sep 2021
    #146
    Hindi pa rin tapos ang thread na ito?!?!?!
    Gee wiz.
    Parang Celine Dion ah. "My heart will go on and onnnnnn..."
    Edit-
    Ganito na lang, upgrade all four tires with the treads of an M1A1. The speed penalty is worth the peace of mind. Kaya lang, what if one comes across a really powerful IED or the latest version RPGs hit them?
    Tsikoteers, what to do?!?!?!
    Apr 2016
    #147
    Naku. Kala ko Rugby is same as rubber cement. Rugby being contact cement is different pala from rubber cement. This is the one exact one used: (nalagay Premium Contact Cement):
    So the shop bought contact cement instead of rubber cement for tire. If hindi pinatuyo muna for 15 minutes bago pumasok. Ano mangyari sa rugby inside? You mean mag remain liquid and hindi ma dry kahit sa air pressure inside the gulong??
    #148
    Quote Originally Posted by k_leos View Post
    Bago ko bili and install new tires. I need to make sure ayus yun pasak na gawa para in case the tires end up with a new user. Hindi ma cause ng harm.
    hack the tyre, so's it is obvious that it can't be used no more, on a motor vehicle, but might still be useful as kariton tyre.
    post here again, after you have purchased your new tyres.
    #149
    Quote Originally Posted by Miles_on View Post
    Gee wiz.
    Edit-
    i don't know about you, but i'm burning time, what with the holidays.
    Jul 2006
    #150
    naku Bostik contact cement has an ethyl acetate in its component which is a Ketone compound that is known to dissolve rubber slowly.
    Hahaha joke lang sir. move on na baka lalong lumaki yang butas ng gulong mo kapag patuloy mo ipinarepair ng paulit ulit.
Plug (pasak) then Patch (tapal) on tire?
