Results 1 to 10 of 217
Threaded View
December 28th, 2021 11:31 PM #7
When you insert the plug, there will be an extension of the plug protruding inside the tire. Since its soft rubber, grinding it will be difficult, thats why the crew will remove it using a long nose plier. In most instances all the plug will come out, some will be left behind.
I prefer to leave some part of the plug behind to cover whatever the patch plus tire pressure could not cover.
A puncture is a puncture, its a hole, removing the nail that caused the puncture will not heal the tire, there will still be a hole in there. Patches and plug do their job to keep the air inside your tire. Unless your tire is made of biodegradable rubber, you should not worry about air and water creeping in a tiny hole.Last edited by glenn_duke; December 28th, 2021 at 11:40 PM.
VinFast VF 3
