UPDATE! UPDATE! UPDATE! UPDATE!
First i'd like to thank everyone here on Tsikot, again and again and again!
From 11.7k pesos to 50 pesos! The advice on getting a 2nd(3rd, 4th and so on) opinion really worth!
We went to 6 autoshop and narrowed down the leak by each shops diagnosis. though i really feel bad because 5 of the shop is free ang check-up.
1st shop is Car Crew, they mentioned what Casa fixed last january and when i bring them the receipt from Casa, they became hesitant and told me to bring the car back sa Casa.
2nd shop was in bucandala, the name is JCM. Sabi valve cover and the engine side (O-ring)
3rd is along aguinaldo hiway, EMS. They said that Vtec, PS pump, Valve cover and engine side (O-ring)
At dahil ang pinsan ko is nag sususpetsa din sa engine side, xa na mismo ang nag bukas. And what he get is a worned out O-ring, halos mapuputol na! So he bought a new one with a bit larger size and is only 50 pesos then replaced it, cleaned everything with brake cleaner and kinabukasan wala ng tulo pero nag mo-moist parin. And so the Autoshop hunt continue...
4th shop was D7, this one isn't free and their result was on the Axle
5th is Rapide at Dasmarinas. Same with Casa, baba transmission and pointing out the crankshaft (Boooooo!)
6th and last stop, A new shop here in Pascam, couldn't find the name kasi ginagawa pa yung place. Magaling ang mga mekaniko according sa pinsan ko. What they saw is, mga tirang oil na lang daw yung nakikita naming moist, my binuksan silang cover dun sa may transmission and andun nga yung tira, sinuggest din nila na e-silicon ang valve cover just to make sure, so pumayag naman ako
Lahat sila, ATF ang tinuro pero engine oil ko ang nagbabawas >.<(Dahil kakulay talaga and dun sa transmission ang leak)
And now, 3 days no leak, no more moist! In the end, yung pinsan ko lang din nakaayos.. But bringing the car for other opinion really help! Napagastos lang din ako sa brake cleaner and gas? Oh and plus the silicon!
Hindi ko lang talaga malaman papano diniagnose ng Casa ang kotse ko without even cleaning to narrow the cause of the leak..
Sorry sa long post, ngayon lang po nagka time and gusto ko lang talaga i-update yung mga tumulong/suggest dito sakin. Thank you po!
