Results 1 to 20 of 28
    May 2019
    Hi po again and again
    After driving the car last week which was this post --> Help on my Civic! My Battery indicator appear but then disappear!
    nagkaroon po ng leak! ma-identify niyo po ba san sya nanggagaling and ano po dapat ipaayos? Sorry if kahit yung basic hinde ko alam... Kapapaayos ko lang po sa Casa nung January sa powersteering and Rack n Pinion, sakop kaya ng warranty ito?
    My Car is a Civic 2010 model
    Quote Originally Posted by Liana View Post
    baka leak galing sa PS pump oil seal.
    try to visit the Honda FD thread... yan talaga ang sakit ng mga civics
    Sep 2006
    Nagbabawas PS fluid?
    yung picture mo i think is the tranmission. so guessing kami either leaking pa nga yung power steering mo or baka nagpapawis na transmission so gasket.
    May 2019
    Dalawa po kasi yung inayos ng casa last january, Powersteering (passenger leak which is okay na wala na ngayon) and yung sa Gearbox or transmission ata yung pagkakaalala ko, which i think is dun nanggagaling ung leak, sa gitna po xa.. Babalik ko po xa sa casa sa friday, sana pasok pa sa warranty..
    Thank you po for checking it out! sasabihin ko po sa casa ito.
    Hard to tell, the color of fouled PS fluid and axle oil is almost the same when smeared to aluminum alloy engine.
    One thing for sure, its a "last-touch" job by casa-with more reason to suspect on poor workmanship, either they did overfill the PS/ damaged a gasket, or axle drain plug was improperly seated/did not replace washer or use threebond gasket.
    Kindly post the receipt po to check the latest job done and narrow down the suspects.
    I like the orange fat cat
    Sep 2006
    I hope maayos na problem. That civic model is a good car by the way. I got to own 2 of these cars way back. And yes, steering naging issues ko din. Even the one I own at present, steering pa rin haha.
    if you haven't brought it back yet, do so now.
    it appears to be a backjob.
    if you attempt tinkering with it, or allow someone else to tinker with it, the backjob warranty may be void.
    May 2019
    Yan po ba yung nasa left side na pula yung cover? ung may upper and lower? hinde naman po bawas nasa line parin po.. Dati po kasi isa yung powersteering sa pinaayos ko sa Casa which is sa passenger side yung leak, ngayon wala na. Yung leak ngayon is sa gitna na po..
    Sep 2006
    Naka admit na ba kotse mo sa kanila? If hindi pa, I suggest pasilip mo muna sa iba just to get a 2nd opinion.
    May 2019
    Di ko po pina-admit. Actually sobrang galit ko kasi, nag pa top-up ako ng oil sa kanila, inilabas nila yung kotse ko and akala ko okay na, dumaan ako sa ibang repair shop, pag bukas ng hood, hindi naka takip ung makina!! Sobrang kalat ng engine bay ko! jusko na Casa Cavite to grabe! Kung nawala yung takip habang nag ddrive ako, babalik at irereklamo ko sya!
    Anyway... Yes po nag pa second opinion muna ako and dito nilinis muna nila yung ilalim and pinababalik ako para malaman san ba talaga nanggagaling ung leak, buti pa dito nilinis nila ng free pa. Sa Casa wala man lang linis na gnawa, not sure pano nila na track na dun ung leak..
    Hinde ba sa transmission ang leak? Parang pula ang fluid eh
    May 2019
    opo nga sir eh, hindi xa ung amoy ng langis ko... Pero nagbabawas yung langis ko sa makina. Pinababalik din sa Casa nung repair shop na pinuntahan ko for second opinion, di nila sure kung san talaga nanggagaling kasi di daw nila kaya ibaba ung transmission, not enough machine daw sila..
    May 2019
    Sir, binuksan po ng pinsan ko ung cover dun sa may crank, wala naman daw po leak pero nagsisimula palang, pero yung sa crank pulley meron daw po talaga which is dun nanggagaling ung langis from my engine.
    Ngayon napansin nya eto, sa may transmission po
    Pula nga po talaga, and makalat po dun sa my dipstick ng atf.. pina-advice niya sakin na linisin muna gamit break cleaner and titignan daw namin..
    Pakalas mo rin air filter box para makita mo doon sa side na yun ng engine. Alam ko meron din isang oil seal diyan.
    Sep 2006
    Wow, what an adventure. I'm happy the issue is settled, for a price like of a darn soda in can. Edi may emotional attachment ka na nyan sa FD mo. Haha. Take care of it. Easily one of the nicest cars around.
    in retrospect,
    a determined mechanic who is not afraid of getting dirty, could have solved it.
    "we all have perfect hindsight."
Please Help with the Leak! (Image inserted)
