Results 21 to 40 of 41
    #21
    masyadong mababaw.. the inner strengthening fibers ain't even seen.
    it's a negligible little nick..
    keep using the tire.
    Jun 2013
    #22
    Thank you sirs. Dalhin ko na lang sa goodyear para matakpan. Nakaka asiwa kasi
    Feb 2009
    #23
    you can take your tire to any vulcanizing shop. what they will do is to patch the nick with emulsified tire tube rubber and vulcanize (cook) the rubber compound to the injury until it is cured. they usually use the same rubber material melted with gasoline or paint thinner until the rubber has turned into a paste or jelly
    Jul 2006
    #24
    I would'nt advise "cooking" those tyres. Uncontrolled heat will do more harm than good. This is why cold patching is the most preferred way in re-sealing punctured tyres.
    #25
    Agree. Lulutong lang yung goma pagniluluto...
    Mar 2004
    #26
    Leave it be.
    I had a similar nick on the side of my tire. And like dr. d mentioned, the inner fibers of the tire didn't show up. So I let it be.
    Nagamit ko siya hanggang napudpod yung treads niya without any incidents.
    Jun 2013
    #27
    Can I ask for a cold patch for my tire damage?
    #28
    In Pinoy-speak: "Malayo yan sa bituka..."
    Jul 2006
    #29
    Quote Originally Posted by vel0city View Post
    I don't know if the repair shop can do that. Just like I said earlier, if you find the superficial damage a bit annoying to look at, then "reverse" the tyre (inside-out).
    Jul 2006
    #30
    Double post
    {[Oo]=I=[oO]}
    Oct 2011
    #31
    basta hindi nabaabwasan tyre pressure at less than 6yrs old pa ang tyre mo go pa rin.
    Oct 2011
    #32
    oops. double post.
    Jun 2013
    #33
    Inaalala ko lang kasi mga sir baka lalo bumuka. Bukod sa pangit :p
    #34
    Those who had problems [moderated posts], kindly send a PM to JEDI or TSIKOT (or both) so they can look into it.
    Jun 2013
    #35
    Thank you sirs inaalala ko lang kasi baka lalo bumuka bukod sa pangit
    #36
    yes, you can. but the repairmen will ask you where you want it placed, because they don't think you need it.
    May 2009
    #37
    OK lang yan basta walang singaw. Nitrogen air din ilagay mo para hindi tumaas ang tire pressure pag long drive.
    Apr 2016
    #38
    Hello Guys,
    Patulong din ako. Safe parin ba gumamit ng ganitong gulong? Nagutter ako tpos napansin ko may damage ung tire
    Apr 2016
    #39
    Di ko maattach ung pics bakit ganun.
    Dec 2009
    #40
    If you have a spare tire, its better to utilize it than taking a risk with a damaged tire
    Sent from my GT-P3110 using Tsikot Forums mobile app
Please Assess: Tire Damage
