Page 2 of 2 FirstFirst 12
Results 21 to 40 of 41
    Feb 2009
    you can take your tire to any vulcanizing shop. what they will do is to patch the nick with emulsified tire tube rubber and vulcanize (cook) the rubber compound to the injury until it is cured. they usually use the same rubber material melted with gasoline or paint thinner until the rubber has turned into a paste or jelly
    Jul 2006
    I would'nt advise "cooking" those tyres. Uncontrolled heat will do more harm than good. This is why cold patching is the most preferred way in re-sealing punctured tyres.
    Mar 2004
    Leave it be.
    I had a similar nick on the side of my tire. And like dr. d mentioned, the inner fibers of the tire didn't show up. So I let it be.
    Nagamit ko siya hanggang napudpod yung treads niya without any incidents.
    Agree. Lulutong lang yung goma pagniluluto...
    Jun 2013
    Can I ask for a cold patch for my tire damage?
    Jul 2006
    Quote Originally Posted by vel0city View Post
    I don't know if the repair shop can do that. Just like I said earlier, if you find the superficial damage a bit annoying to look at, then "reverse" the tyre (inside-out).
    yes, you can. but the repairmen will ask you where you want it placed, because they don't think you need it.
    May 2009
    OK lang yan basta walang singaw. Nitrogen air din ilagay mo para hindi tumaas ang tire pressure pag long drive.
    Apr 2016
    Hello Guys,
    Patulong din ako. Safe parin ba gumamit ng ganitong gulong? Nagutter ako tpos napansin ko may damage ung tire
    Apr 2016
    Di ko maattach ung pics bakit ganun.
    Quote Originally Posted by akosieric View Post
    Hello Guys,
    we can't see the tire.
    but if the tire's damage is on the sidewall, but only superficial, it might still be usable. how superficial, is hard to say without pictures.
    but if the damage is big enough, such that the patch flexes when the tire is manipulated, whether at the sidewall or the tread, then that tire is done for.
    Jun 2013
    Inaalala ko lang kasi mga sir baka lalo bumuka. Bukod sa pangit :p
    Dec 2009
    If you have a spare tire, its better to utilize it than taking a risk with a damaged tire
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Jun 2013
    Thank you sirs inaalala ko lang kasi baka lalo bumuka bukod sa pangit
Please Assess: Tire Damage
