Results 11 to 20 of 24
Toyota is my choice
- Aug 2005
- 2,063
May 30th, 2007 12:17 AM #11
May 30th, 2007 10:14 AM #12
eto tunog pag try ko start.
i-rename niyo na lang yung file kasi di puwede yung WAV na i-upload eh.
redondo 2.txt -> redondo 2.wav
May 30th, 2007 07:19 PM #13
napalitan ko na yung map sensor.
hindi pa rin umandar!
sabi nung pinagbilan ko dalhin ko yung distributor ko sa kanila
sakaling hindi pa rin gumana yung pagpalit ko ng map.
ang suspect niya is yung ignition coil daw. dalhin ko daw sa kanya para
ma-test niya. posible ba na ma-test niya yun?
isa pang ginawa ko kanina, ni-check ko kung may spark yung mga hi-ten wires. wala.
May 31st, 2007 01:52 PM #14
i need to troubleshoot the ignition coil and igniter unit.
but the rotor is a PITA to take out!
my pdf manual says there's a screw. but there's none! how do
i take this f*#k out?
June 1st, 2007 09:03 AM #15
If there is no screw on it just pull it out. Don't forget to check also all fuses and relays.
June 1st, 2007 09:44 AM #16
nakahanap ako ng mekaniko kahapon. checked niya lahat.
diagnosis niya, mahina na ang bigay ng spark. binaklas niya ang
dizzy, dadalhin ko sa evang today para mapalitan yung parts.
ang ginawa nung meka, habang ini-start ko (redondo) tanggal niya
yung mga hi-ten then placed near sa ground. may spark pero
mahina daw at iba ang kulay. dapat ba may kulay yun? not enough
daw to burn the fuel.
June 3rd, 2007 11:59 AM #17
ignition coil replaced.
naikabit ko na yung dizzy ko.
nakapagpa-karga na rin ako ng battery.
ayaw pa rin mag-start ang oto. (
- Nov 2006
- 299
June 4th, 2007 02:54 PM #18
- Sep 2006
- 52
June 4th, 2007 05:45 PM #20
may nakausap na ako sa honda makati. pupunta daw sa bahay bukas.
balitaan ko kayo kung ano ang findings niya.
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
