Results 1 to 7 of 7
November 9th, 2010 05:52 AM #1
mga sirs tanong lang hindi ba masama sa kotse if nakapark ng ganyan palagi?
bago kotse ko 2011 altis a/t e inaalala k kasi un brake or handbreak hindi ba masisira yun kapag lagi ganyan ang parking? kelangan ko pa ba magkalso?
thanks po!
November 9th, 2010 06:25 AM #2
I read somewhere that for A/T cars, the proper way to park uphill/ downhill is to put car in neutral while stepping on the brakes then put the hand brake up. (make sure that you crank it up to the maximum) Slowly let go of the brake pedal and make sure the hand brake's holding up. Switch off the engine then shift to park. After doing this procedure, haven't had any problems with shifting from park to reverse or drive when parked uphill/ downhill. Although i might be wrong.. let's wait for the expert to shed some light on this..
November 9th, 2010 07:14 AM #3
- Jul 2003
- 573
November 9th, 2010 09:52 PM #4the procedure should apply to all type of parking conditions.
for additional safety you should do the following:
1. when parking downhill, point the wheels towards the curve or gutter
2. when parking uphill,point the wheels away from the curve or gutter
November 9th, 2010 10:20 PM #5
korek!!!
tandaan, bago ipasok at bago alisin sa P ang gear control....press the brake pedal first.....
kung magpapark.... 1.brake pedal-2.hand or parking brake then 3.shift to P.
kapag nauna kasi ang P kesa sa Parking brake, unang naka-engage ang tranny mo kesa sa preno....so, nandun sa tranny ang load......
- Jun 2010
- 76
November 16th, 2010 11:40 PM #6basta lagi mo unahin ang hand brake engage..sa luma na kotse masama yun ganun lagi nakapark kasi yun engine oil nawawala sa oil pan so ang nangyayari ay yun oil pump ay wala makuha pede masira ang bearing..yun desgn ng altis ngayon ay meron na baffle palte sa oil pan para maiwasaan mawala ang engine oil pag naka park ng uphill and downhill..sana ay makatulong ito sa inyu..
- Jul 2003
- 573
November 19th, 2010 11:52 AM #7anong sasakyan ang nawawalan ng oil kapag nag-park ng uphill o downhill? baka naman kulang na kasi ang langis kanya nawawalan ng langis na mahigop ang oil pump. At saka, paano na kung paakyat ng matarik na bundok ang sasakyan?
baka naman sobrang tarik naman ang parking?
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
