mga sirs tanong lang hindi ba masama sa kotse if nakapark ng ganyan palagi?
bago kotse ko 2011 altis a/t e inaalala k kasi un brake or handbreak hindi ba masisira yun kapag lagi ganyan ang parking? kelangan ko pa ba magkalso?
thanks po!
thanks po!
I read somewhere that for A/T cars, the proper way to park uphill/ downhill is to put car in neutral while stepping on the brakes then put the hand brake up. (make sure that you crank it up to the maximum) Slowly let go of the brake pedal and make sure the hand brake's holding up. Switch off the engine then shift to park. After doing this procedure, haven't had any problems with shifting from park to reverse or drive when parked uphill/ downhill. Although i might be wrong.. let's wait for the expert to shed some light on this..
the procedure should apply to all type of parking conditions.
for additional safety you should do the following:
1. when parking downhill, point the wheels towards the curve or gutter
2. when parking uphill,point the wheels away from the curve or gutter
korek!!!
tandaan, bago ipasok at bago alisin sa P ang gear control....press the brake pedal first.....
kung magpapark.... 1.brake pedal-2.hand or parking brake then 3.shift to P.
kapag nauna kasi ang P kesa sa Parking brake, unang naka-engage ang tranny mo kesa sa preno....so, nandun sa tranny ang load......![]()
basta lagi mo unahin ang hand brake engage..sa luma na kotse masama yun ganun lagi nakapark kasi yun engine oil nawawala sa oil pan so ang nangyayari ay yun oil pump ay wala makuha pede masira ang bearing..yun desgn ng altis ngayon ay meron na baffle palte sa oil pan para maiwasaan mawala ang engine oil pag naka park ng uphill and downhill..sana ay makatulong ito sa inyu..
anong sasakyan ang nawawalan ng oil kapag nag-park ng uphill o downhill? baka naman kulang na kasi ang langis kanya nawawalan ng langis na mahigop ang oil pump. At saka, paano na kung paakyat ng matarik na bundok ang sasakyan?
baka naman sobrang tarik naman ang parking?
