Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
    Jul 2006
    #21
    clutch?
    sama ko na rin tanong ko.
    kapag naka aircon ako parang nag sslide yung oto ko
    pero kapag ndi naka aircon, ok na naman pero around 3k-4k ko feel yung hatak.
    Apr 2006
    #22
    Quote Originally Posted by sirmykel View Post
    clutch?
    How old your clutch lining and pressure plate? Mararamdaman mo naman yan kung mataas na yung rpm mo tapos ayaw pa rin bumatak sliding clutch na nga pero kung ayaw lang bumatak at hindi mo napapagallit ang makina ng oto mo complete tune-up lang. I had experienced it before changed lang ako ng spark plug at konting re-gap lang ok n uli.
    #23
    Quote Originally Posted by cablespy View Post
    Car: Corolla gli ae101
    Symptoms:
    1. palyado (intermittent)
    2. mahina hatak
    3. nangiginig pag may aircon
    4. hirap paakyat sa incline
    Service done:
    1. Changed sparkplugs
    2. Changed Fuel filter
    3. Change oil/ oil filter
    4. timing
    5. cleaned throttle body, intake manifold and injectors
    Problem still exists. kanina paakyat ng parking ng eastwood tinulak nalang kasi di na kaya paakyat. I've brought this to several mechanics already including casa and it's still not fixed. What is the most possble cause?
    Update (april 1, 2007):
    1. swapped with known good computer box- NOGO
    2. swapped with known good servo - NOGO
    3. swapped with known good distributor -NOGO
    Hi newbie here, why not bring your car to the shop for another opinion? If you happen to passby QC area, why not drop by D2H Autoworkz and look for Danny Hipolito. Maybe he can have a look at it again before you buy another ECU. You can call the shop at Tel. 4159003. Try it bro.. Salamat
    #24
    Quote Originally Posted by t2erns View Post
    check cam timing might slip a tooth... my 2cents
    true...this normally happens sa mga corolla with almost worn out belts, ang resulta nagbabago-bago ang timing. my other suspected problem is your valves. singaw barbula.. oil gets into your valve chamber. minsan this happens pero di umuusok. it definitely causes power loss, and sometimes hard starts. since your car is a corolla, you might want to check and ask for help at grupotoyota.com.ph forums. There you can get good advice regarding your car problems and they will guide you on where you could take your car to be fixed through their shared experiences. Goodluck!
    Sep 2005
    #25
    sori kung ot pero parang related sa topic. pa-change oil ako kahapon kasama palit spark plugs, nung tinanggal yung HT wires sa #1 and #2 may nakitang oils. possible po ba na head gasket ito? sabi kasi nung mechanic rubber/oil seals ng spark plugs lang papalitan. help naman po. tia
    Oct 2003
    #26
    Quote Originally Posted by d2h View Post
    Brought my car to D2h. Thank God they had a good ECU to test with. Kudos to Danny of D2H for finally solving the problem.
    Thanks to everyone else who helped. Mabuhay ang tsikot.com!
palyado: need expert help
