Tune-up and cleaning throttle body fixing most problem of different cars. Yun nga lang mas mahigit pa dito ang kailangan ng tsikot mo. I forgot to mention before about the fuel pressure of your engine. Sometimes when the pressure drops, it gives a big different from smooth running into hesitating of your engine. Sabi mo nga napalitan na ung computer box. Try concentrating on wiring rather than changing the computer box. Most especially by checking engine and accessory ground voltage drop. Don't forget to check also supply voltage from ECM to sensors. Intermittent problem is difficult to fix so good luck na lang pre sana maayos na tsikot mo.
