nag pa change fuel filter ako ng pajero gen 1 sa isang service station. later, it seemed that the temperature gauge wasn't functioning. if i remember right, konting andar pa lang, tumataas na yung needle sa middle at stable na siya doon. kanina pina idle ko ng matagal,hindi gumalaw. now i'm not sure anymore. baka me nagalaw yung mechanic?
may i ask you guys kung tama lang yun o something's wrong. if ever, saan ko pwede itrace yung diperensiya?
hindi ko na mabalikan yung nag service kasi malayo.
as always, thank you for your kind tips and suggestions.
mine is a fieldmaster, pero mukhang pareho lang ata gauges niyan. mabilis tumaas ang gauge ko. siguro may na disconnect lang na wire yan. pa check mo sa mechanic o electrician para sigurado. good luck.
or you can look at your engine compartment and look for a piece of wire that was disconnected. The wire regularly can be found by following the hoses or pipes connecting to your radiator : )
Need help sa temp gauge ko. i left my car for 10 days, tapos pagbalik ko yung temp ko konting taas lang halos nakapatong lang sa lower marker. dati rati kasi nasa half siya. meron po ba kinalaman ang tagulan dito? and may kinalaman ba ang glow plugs sa temp gauge kasi minsan naririnig ko tumutunog yung tik sa glowplugs kahit nagamit ko na.
