Results 1 to 17 of 17
    Mga bossing ano magandang gamitin sa Honda Civic na Lxi?
    I ask shell gumagawa sila -P- 30.00 lang daw kaso sa kanila mo daw bibilhin. Anong Magandang shell product?
    Thanks.
  2. #2
    bro gear oil for what? front wheel drive ang Honda and wala itong rear differential.
    Sa kambyo boss
    Tama ba ako
    My friend tell me na I need to replace na yung gear oil kasi may sabit na yung kambyo.
    Tama ba ako?
    Thanks
    Gear oil should be changed every 40,000km (along with brake fluid, coolant and all the filters). More often if you get into floods.
    Check with the owners manual on the specs of the gear oil needed for your ride.
    Boss Vinj;
    Sabi sa akin kahit daw hindi specific dun sa owners manual kahit engine oil daw pwede wag lang synthetic.
    Boss tama po ba?
    Well, i wouldnt bank on that. Its best to use what the manufacturer recommends when it comes to oils para walang sabit. The cost difference isnt much and you can easily find naman gear oil around so why bother to use something else?
    That's my opinion.
    Thanks vinj
    boss clavel - sa manual ng EK ko, ok lang gumamit ng engine oil! - im not particular about the rating though!
    Pag sa Honda Motor oil ang ginagamit. Don't use gear oils. di compatible sa Honda tranny.
    Actually dapat may Genuine Honda MTF pero di available locally. nakalagay sa manual use Motoroil temporarily. best bet is to use motor oil tapos every 20t km ang palit
    Sa casa 20w-50 nilalagay.
    Meron sa shell ba nito?
    I ask sa shell .
    thanks.
    the owners manual is one of your best buddies pagdating sa maintenance ng ride kaya check nyo yung specs ng oil na nakalagay dun...in my case, sa manual ng EK ko specified is engine oil...tulad ng sabi ni Supierreman engine oil na 20W-50 ang kadalasang inilalagay...
    pls. check your manual sir CLAVEL3699 para sigurado ;)
    Sir Chieffy;
    Yun nga problem ko eh. Tinapon nang esmi ko yung manual kala daw nya basura na sa car eh.
    pwde ba 20w-50 na din gamitin ko. Meron naman siguro sa shell nito.
    Thanks.
    Thanks for the infos, i wasnt aware of the engine oil useage issues with the HOnda trannies.
    Sa tsikots namin, GL-4 gear oil is the recommendation.
  15. #15
    Tama si Sman. Hindi gear oil rally coz sae90-120 ang gear oil generally w/c is very malapot. . Normally motor oil din ang ginagamit sa Honda tranny which is 20W-50.
    Jan 2004
    Thanks.
    musta na po? actually anything. basta motor oil dapat ang ilagay mo.
    Ito Ian_rex dami ko na problem sa car eh.
    Tagal na kasi sya.
    Thanks pagawa ko na sya sa sat. sa shell station.
Change: gear oil
