Results 1 to 10 of 17
May 31st, 2004 09:26 PM #1
Mga bossing ano magandang gamitin sa Honda Civic na Lxi?
I ask shell gumagawa sila -P- 30.00 lang daw kaso sa kanila mo daw bibilhin. Anong Magandang shell product?
Thanks.
- Dec 2002
- 2,335
May 31st, 2004 10:19 PM #2bro gear oil for what? front wheel drive ang Honda and wala itong rear differential.
June 1st, 2004 12:47 AM #4
My friend tell me na I need to replace na yung gear oil kasi may sabit na yung kambyo.
Tama ba ako?
Thanks
June 1st, 2004 09:27 AM #5
Gear oil should be changed every 40,000km (along with brake fluid, coolant and all the filters). More often if you get into floods.
Check with the owners manual on the specs of the gear oil needed for your ride.
June 1st, 2004 02:02 PM #6
Boss Vinj;
Sabi sa akin kahit daw hindi specific dun sa owners manual kahit engine oil daw pwede wag lang synthetic.
Boss tama po ba?
June 1st, 2004 02:11 PM #7
Well, i wouldnt bank on that. Its best to use what the manufacturer recommends when it comes to oils para walang sabit. The cost difference isnt much and you can easily find naman gear oil around so why bother to use something else?
That's my opinion.
June 1st, 2004 03:06 PM #9
boss clavel - sa manual ng EK ko, ok lang gumamit ng engine oil! - im not particular about the rating though!
June 1st, 2004 03:24 PM #10
Pag sa Honda Motor oil ang ginagamit. Don't use gear oils. di compatible sa Honda tranny.
Actually dapat may Genuine Honda MTF pero di available locally. nakalagay sa manual use Motoroil temporarily. best bet is to use motor oil tapos every 20t km ang palit
Sa casa 20w-50 nilalagay.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
