Page 1 of 2 12 LastLast
Results 1 to 20 of 29
  1. #1
    Hi.
    A funny thing happened to me when I shifted from M/T (RAV-4) to A/T (Forester) - my right leg started hurting!
    I think it's got something to do with seating position because each car has different ergonomics, so to speak. Even the pedals (accelerator and brake) have an effect I think.
    I started adjusting the height of the seat, as well as the recline but the pain persisted. So I adjusted the seat so I'm closer to the steering wheel and my upper leg (almost to the knee) is supported by the seat. The pain is starting to fade, thank goodness. Nadismaya nga ako kanina because I forgot to tell the car wash boys not to adjust the driver's seat when they vacuum. Lagot na naman 'to bukas
    Ano ba talaga ideal driving position? I used to think dapat almost stretched fully ang right leg (only slight bending when you press the pedals). Tama ba yun? Is there such a thing as correct seating position or does it depend on the driver?
    Oct 2011
    depende sa driver yan seating position. ung iba sobrang stretch at recline ung tipong parang nakahiga na.
    Dec 2007
    Correct seating position is the foundation of all driving and it's even more important if you're racing or competing.
    1. Make sure that your buttocks are firmly wedged in the crevice between the seat back and the seat squab. Adjust the seat back angle until you are seated straight and have your bottom in the prescribed position.
    2. Slide the seat backward, then extend your arms over the steering wheel. You should be able to place your wrists above the steering wheel without reaching over or bending forward from the seat back. When you transition your hands over to the 9-and-3-o'-clock position, your arms will have a slight bend to them. This is important - you want maximum leverage on the steering wheel in order to perform quick corrections.
    3. Make sure that your feet have enough leverage as well. You should be able to depress the clutch and brake pedals to the floorboard and still have a slight bend to your knee.
    4. Never, ever, ever use the inside of the steering wheel to turn. Use the outer rim. Why? It's harder to make corrections mid-turn if you use the inside of the steering wheel.
    EVERYTHING about what I shared in this post is about having maximum leverage - and it starts with your hips and back being situated in the correct position on the seat. The more leverage your limbs have, the more control you have on the car, the less effort needed, and the more comfort you will have driving. Hope this helps
    Dec 2007
    Quote Originally Posted by April_Ryan View Post
    Hi.
    The failing of so many stock car seats is that their seat squabs are just too damn short. This is exactly the reason why I swapped out my Jazz's stock seats for Recaros.
    If the seat squab is too short, and you have long thighs and legs, your knee will inevitably be left without any support. On longer drives this will be painful. This is usually evident if the seat itself is set rather high.
    If you have height adjustment on the seat, set it as low as it can go. Lowering the seat height forces your whole leg to a more horizontal position, which is easier on your thigh and knee and allows you more leverage on the pedals.
    Case in point: I used to drive an old 1999 SX8 Honda City, which is based on the 1988-1991 EF Honda Civic. The seating position on that car is very low, with your legs almost parallel to the floor. It's very comfortable even on long drives despite the small seat and short seat squab. When your legs are closer to parallel to the floorpan, thigh and knee support stop mattering as much.
    Hi.
    Ilang taon mo na ba Bro?
    Ok yung sinabi ni Type_100, pero sa #1 mas prepared ko na naka-inclined yung sandalan (somewhere in 75-85degrees) lalo na pag long drive. Because of inclination, nale-lessen yung weight na dinadala sa gawing hip/waist natin.
    Since sa leg ang problema mo, dapat nakalapat yung buong legs mo sa upuan.
  6. #6
    ^very helpful, thanks. Will take these into account when I adjust seats tomorrow.
    almost the same thing happened to me too when i began driving cars w/ automatic trannies after a lifetime of traversing around w/ stick shifts. the difference though is that in my experience it would be my left leg which would go numb or fall asleep (aka ngawit) because of its apparent inactivity. eventually though, i guess i just grew accustomed to motoring about w/ only my right leg doing the work
    Feb 2009
    it could be driver health condition. we don't get younger and better physically after a certain age. it might be the position you slept the night before. maybe you need to see a chiropractor, he might be able to help. explore the possibilities, after all, it might not be the car that has a problem, it might be the car-driver match.
    Jan 2009
    Type100 brought up a number of good advice. But about setting the seat height to the lowest setting, I think that it may not be for everyone and can be a problem with most short drivers, even with the backrest set to almost vertical. I'd adjust it as low as I can possibly tolerate, or without losing too much front visibility.
    I'd also want to add that most steering wheels are adjustable in both angle and distance relative to the driver. If this feature is available, use it. However, it should be adjusted last using the wrist-on-the-wheel method, not the other way around.
    Drive like PUJ drivers yun halos naka side na yun katawan...
    Sent from my iPad using Tapatalk HD
    Oct 2007
    * April_Ryan,
    just my two cents worth.
    1. the hip joint suffers whenever your seat is set to the lowest position. the stresses are multiplied 3 fold at this hip flexion position. this means that your bend at the hip should be set to almost 90 degrees only. if your seat position is too low, try looking at your knees in relation to your hip/waist. if you are constantly finding that your waist is way lower than your knees, then this will punish your hip and legs.
    2. you cannot do anything if your seat is short or shallow in depth. a short seat puts too much tension on your quadriceps ( muscles in the front of your thighs) and obviously leaves the back portion of your thighs (hamstrings) hanging in space without anything supporting it. in long drives or bad traffic conditions, this puts your muscles to work in a disadvantaged position. i would suggest to you to keep your back as close to the seat as possible. this means your entire back should touch the entire seat. and the position of the seat is supposed to be set at 90 degrees or straight. think of a marine or a PMA cadet: 90-90 means straight back and straight knee.
    3. the position of your seat also affects the pressure on your lumbar spine. the slouched position will punish your lumbar spine. ( your low back area). driving gangsta style is a no no especially in long drives, and as we get older. keep the seat in its highest position if you can. then adjsut the steering wheel to its highest position so that you will have enough clearance for your thighs when you drive.
    4. i hope you are not driving with your wallet in your Right back pocket. this creates a pressure effect on one of your big nerves, the sciatic nerve. this then creates tingling and pain ( paresthesias ) in your Right thigh and leg.
    try to check every point i raised and look at your car with the door on driver side wide open. try to see if your seat is in a low position, and if the back is straight, or leaning towards the back.
    hope this helps.
    May 2008
    your wallet might be putting pressure on some nerve or vessel. specially if its thick crammed with bills, coupons, credit cards and the like.
    Dec 2007
    Quote Originally Posted by goldrat View Post
    This is correct, and a notable observation.
    This is especially true when you are sitting on only one wallet, so the pressure that your butt cheeks have to carry is different. Not only will there be possible pinching of a nerve, blood vessel or muscle (runners make reference to the piriformis muscle, hidden in the butt cheeks), but also slight misalignment of the spine. Over a long drive this will make itself known.
  14. #14
    guys,
    No wallets in back pocket for me, as I'm a female. I keep wallets in my bag
    Age though, might be a factor, as I'm no spring chicken. Hahaha.
    I'm monitoring the pain. Due to car wash yesterday, car wash boys moved my seat and pain started up again when I drove today. Couldn't find the position which agreed with me. Drat.
    I think it's seat height + distance from pedals (i'm getting conflicting advise re whether seat should be high or low, so I will just experiment). And I can't figure out if my present car seat is longer or shorter than my previous one as old car is no longer with me.
    Dec 2007
    Let us know what happens.
    If you do resort to lowering the seat height, you might have to get used to the view. With the seat swap on my Jazz, the H-point (hip point) went down 2" and it was very noticeable, and it took me a couple weeks to confidently navigate with the lower seat and seat rail height. I doubt that height-adjustable stock seats will have that much of a difference, though.
    For illustration purposes, using bottles of beer:
    Oct 2007
    Ma'am,
    if all else fails, see an orthopod or a neurologist. skip the chiropractor first. you have to establish a sound medical diagnosis before proceeding with any manipulation by a chiropractor. i have seen one too many complications after people subject themselves to manipulations done by poorly-trained chiropractors.
    this is a public forum and it is not unusual to get conflicting advice. however, if advice is coming from a professional, then its weight trumps majority of the submitted opinions from our other respected forumers. i hope i did not offend anyone.
    happy driving!
    Sis,- try changing the position of your left foot/leg once in a while... It should change the weight distribution when you are seating.
    I also experienced something similar years ago when I shifted from M/T to A/T... It must be what our body was accustomed to, when driving...
    17.4K:date:
  18. #18
    Update - I think I've settled on a seating position. Mostly no pain this week, except tonight due to godforsaken traffic in McKinley.
    Ano ang naging prepared setting mo Mam, straight or inclined yung sandalan, mataas/mababa, mas malapit/malayo sa manibela?
    Feb 2009
    so, it was a matter of ergonomics, not a problem with the car. it was the car-driver interrelations or interface
Pain in right leg while driving
