Results 1 to 17 of 17
    gud eve mga mates.. mga sir pwede ba malaman yung step by step procedure kung pano mag tune up?
    br..
    anong ride: diesel na normally aspirated or diesel na efi, gas na normally aspirated o gas na efi?
    Nov 2003
    efi normally only needs replacement of plugs.
    adjusting tappets and replacing fuel filter are extra na.
    Jan 2003
    pagka diesel ba anong tune up ang kelangan?
    Jul 2006
    how about for a carbureted engine like 4af?
    oo nga po, paano pag carburated engine?
    May 2005
    Quote Originally Posted by ej_saiyajin4 View Post
    replace spark plug every 10,000 kms, linis every 5,000 kms.
    replace air cleaner every 10,000 kms, clean every 5,000 kms.
    replace fuel filter every 20,000 kms
    since medyo luma na 4af, have your carb cleaned every 5,000 kms using carb cleaner.
    replace clutch and brake fluid every 15,000 kms.
    flush radiator every 10,000 kms or every year, whichever comes first. pwede DIY madali lang, you can search this forum for it.
    Quote Originally Posted by speedyfix View Post
    talking about tappets, ano ba recommended frequency ng pag-check or adjust nito?
    Nov 2003
    normally every 40k kms.
    Sep 2006
    ano yung tappets?
    Jul 2006
    guys i have a 2003 Mitsubishi lancer MX. I'm planning of changing the SPARK PLUGS of my ride. If i shift to DENSO IRIDIUM, how will my fuel consumption and performance be affected?
    thanks guys..
    tanong ko lang kung self adjustment tuppets ba yung sa corolla 4AF engine?nag tanong kc ako sa mechanic eh self adjustment daw?kc yung engine ko eh may naririnig ako na maingay parang ang tunog eh yung sa tuppet nga maingay kc parang tunog ng diesel na makina,pero pag uminit naman yung makina eh nagiging smooth naman nawawala na yung tunog?normal lang ba ito?
    Nov 2006
    share ko sa inyo kung paano ang complete tune-up job, {1st},check the valve lash (valve tappet clearance) with the filler gauge,adjust it if possible,usually .039-.041 of an inch,,{2nd}.check the ignition timing(retard or advance){3rd}replace the spark plug and with the DMM check the resistance of the spark plug wires(6000-8000 ohms/foot),{4th}check the battery and battery cable,then do the battery test (12.6V-9.6V),charging test (14V-15V) and draw test (.2 amps or 20 ma).{5th}check the hooses(pcv,vent,egr,coolant,vacuum hoose to brake booster,etc.).{6th}fi service or bg service.{7th}optional--change engine oil and filter---top off all fluid (coolant,wiper res.,brake,power steering,,,,,,,,start the engine for 5 seconds and then turn it off then check the oil level,,check for leaks.
    Oct 2004
    Quote Originally Posted by 2Dmax View Post
    thanks guys..
    no noticable effect on performance and fuel consumption....
    basically, iridium spark plugs are long life plugs.... para sa mga tamad maglinis magpalit ng spark plugs... less maintenance.... yun lang po....
    m, i'd rather change my stock/ordinary spark plugs kahit every 5000kms since mura lang naman... naka-5 changes ka na ng stock/ordinary which is equivalent sa magagastos mo sa isang set ng iridium.
    Sep 2006
    just do a italian tuneup.Wot wot.
    Nov 2003
    normally if you need to ask what needs to be done, you are better off letting an expert do it for you.
    Oct 2004
    nice advice sir...
    sometimes, the DIY does not really turn out to be do-it-yourself, but rather destroy-it-yourself....
paano mag tune up?
