Originally Posted by
sonjeffrey
Why add o2 sensor by the way? It will only mess up your system.
if ECM/PCM was not designed to take data form HO2S1 or HO2S2 if you have cat conv, what's the use?
The main function of these Heated Oxygen Sensors are just to read whether your system is mean or rich. and from that, your ECM/PCM will give an output to the injectors, MAF, etc to control your fuel/air distribution. If the ECM/PCM is not designed to read data from HO2s, so why add it.
Note: If your modules are ready for H02s, on installation, be sure that no leak on the fittings of the sensor.. It will cause wrong reading of this sensor.and again will mess your system, and you might suspect that you have a vacuum leak before your intake manifold.
