That's quite possible.Originally Posted by speedyfix
I once helped out a friend who had his Toyota engine sieze on him at 50 kph. The engine ran out of oil because it had a leak and the owner somehow forgot his morning routine of pouring in a quart of oil. Good thing he was quick enough to punch the clutch in, allowing him to regain control of the vehicle.
Well, to make an already long story short, I took out the sump, sprayed some WD-40 on to the crankshaft and underneath the pistons. I also took out the sparkplugs and sprayed some (not too much) into the cylinders. A few cranks and the engine started right up. (The engine previously would not budge, even when push started in first gear.) If he hadn't only broke a conrod, he would have been able to drive the car much longer before he finally had to switch to a newer one.
