Results 1 to 10 of 12
March 7th, 2005 01:59 PM #1
What do I do with unused / leftover motor oils (less than a liter).
I have some Mobil1 (regular & synthetic) & Caltex (energy synthetic). Might not be using them again since I'll be switching to a higher viscosity oil (Castrol Magnatec 10W-40) from Caltex Energy (5W-30) for the 323.
- Jun 2004
- 1,311
March 7th, 2005 02:03 PM #2Well, you can still mix them in to your engine, different oils can work together anyway. Or maybe you can always ask your neighbor or friends here if anyone needs some extra for topping up.
- Mar 2005
- 227
March 7th, 2005 02:26 PM #4Originally Posted by mazdamazda
Just curious, why would you switch to a higher viscosity oil for the 323?
- Jun 2004
- 1,311
March 7th, 2005 02:41 PM #5Less leaks pag higher rating?
Sa car namin nung 30w-50 walang leak, nung 10w-40(or somethink like that) nagkaroon ng oil leak.
March 7th, 2005 02:49 PM #6
lam ko pwede lang pagsamahin pag pareho viscosity rating.
kung kokonti na lang naman, i would suggest na lagay mo na lang sa isang lalagyan tapos gamitin mong lubricant for example sa mga squeaking hinges sa pinto, etc.....
March 7th, 2005 03:01 PM #7
If I remember correctly, there's a DOST-sponsored program for recycling used motor oils. Try their website for info.
March 7th, 2005 04:53 PM #8
Originally Posted by Juan Tamad
March 7th, 2005 05:02 PM #9
ganun po ba?...well ko dito,i use only helix blue on the kia and maxima..
sa gas station,i request in 4 1-liter bottles..keep ko ung 1 liter and pour the remaining old stock that i have...ngayon nakaipon tuloy ako ng 4 liters..
ung unused oils may be used nga sa door rail ng sliding door sa bahay...mga konting langit-ngit ng hinges,etc...sa car,pwede din sa door hinges,some underchasis parts....
used oil naman gamit namin sa dogs to kill the galis..
pero kung madami-dami,pwede naman ata paghaluin ang same oil viscosity then give mo sa may kelangan...
- Oct 2004
- 138
March 7th, 2005 05:21 PM #10Originally Posted by mazdamazda
puede pa yun bro.
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
