Results 1 to 6 of 6
- Jan 1970
- 21
June 30th, 2003 10:53 PM #1napansin ko lang, ung isa sa mga spark plugs ko may langis sa tip (ung nagpoproduce ng spark). ano po kya reason for this? remedy?
July 1st, 2003 12:01 AM #2
baka may tagas na sa engine mo... nangyari din sakin yan nung naputulan ako ng timing belt eh... buti nalang naagapan agad.
patingnan mo nalang agad sa mekaniko mo.
- 19
July 1st, 2003 07:47 AM #3Have ur engine checked, maybe the valve seals are wearing out, or other components in the engine.
Is it just the oil in the sparks that u see? how about ur smoke? are u emitting too much white smoke na? How about the "hatak" are there any changes?
July 1st, 2003 12:26 PM #4Originally posted by nick
Improper timing
rich air/fuel ratio
or leak sa combustion chamber
- Jan 1970
- 21
July 2nd, 2003 08:14 PM #5Is it just the oil in the sparks that u see? how about ur smoke? are u emitting too much white smoke na? How about the "hatak" are there any changes?
hatak is not the same. there is no white smoke though. my ride is a series 2. therefore, no timing belt na mapuputol. just a timing chain na i guess would be hard to break.
July 4th, 2003 10:02 PM #6
i dont mean to scare you but there is a possibility that blowby na makina mo.
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
