Results 1 to 6 of 6
    Jan 1970
    napansin ko lang, ung isa sa mga spark plugs ko may langis sa tip (ung nagpoproduce ng spark). ano po kya reason for this? remedy?
    baka may tagas na sa engine mo... nangyari din sakin yan nung naputulan ako ng timing belt eh... buti nalang naagapan agad.
    patingnan mo nalang agad sa mekaniko mo.
    Have ur engine checked, maybe the valve seals are wearing out, or other components in the engine.
    Is it just the oil in the sparks that u see? how about ur smoke? are u emitting too much white smoke na? How about the "hatak" are there any changes?
    Could be any of the following:
    Improper timing
    rich air/fuel ratio
    or leak sa combustion chamber
    Jan 1970
    hatak is not the same. there is no white smoke though. my ride is a series 2. therefore, no timing belt na mapuputol. just a timing chain na i guess would be hard to break.
    i dont mean to scare you but there is a possibility that blowby na makina mo.
oil on sparkplugs
