Results 1 to 14 of 14
    Oct 2003
    mga peeps gus2 ko sana pabutasan yung rotor disc ko n parang brembo...... pero anu anu kaya maging side effef nito... BTW pina reface ko n tong rotor ko hind naman nagwewego pagnagprepreno,.... para pumorma lang ng konti.... what do u think??? ty a bunch s mag magrereply takot ko kasi baka pag binutasan ko mag wego or magcrack pag mainit n kasi yung brother ko nagpalit ng rotor disk na brembo n ventilated nakakingit kasi e ty",)
    hindi ba iba ang steel properties ng tunay na brembo rotors sa stock rotors? baka lumambot lang yang stock rotors mo kapag pinabutasan mo. bumili ka nalang ng tunay na brembo, imho.
    Signature
    Oct 2003
    oonga no........ mahal kasi e... e kayo guys what do u think more feedback please...
    See related thread:
    - Upgraded Stopping Power...
    try to contact Auto_Xer, he can do cross drilled rotors safely, dapat kse may certain number and distance yung mga holes, try mo din yung z-speed na brand yata, arnd 12t a pair pang civic, the shop is along e.rodriguez ave., near espana
    Oct 2003
    ungas very risky pala yan... nakakatakot tuloy baka mag sisi pa ako.... yung nasa pic na pinakita mo sakin ganung klase yung s brother ko ganda talaga
    trup, ganun din yung sabe skin ni mato sakin e may kakilala n b kyo n nagpabutas and wala side effeks....ty a lot
    A famous machine shop told me it is a very risky task. But their customers still insist on doing it. Minsan di naman perfect and balancing na nagagawa sa drilled rotors.
    Bili ka na nga lang ng pre-drilled na, then balance it before mounting it on your vehicle para siguradong walang brake shrudder and failure.
    Oct 2003
    risky pala talaga...... cge sir ungas ty a bunch ha dko nalang papagawa kasi baka masabihan pako ng trying hard mag brembo hehe tnx
    Unless you plan to go on the track or drive really hard in the mountains, upgrading your stock pads, lines, and brake fluid will be quite a good improvement.
    Cross drilled rotors dont really give better braking distances but rather give better fade resistance. If you get aftermarket rotors, get dimpled or slotted ones as opposed to drilled ones as these can crack easier.
    i have a slightly used brembo rotors w/c i used to use at the rear brakes of my civic, pero di sya cross drilled.....4sale
    Nov 2003
    Around how much po ba Brembo rotors? and will it fit sa '94 Corolla Gli?
    Check Bremo website andun po ang iba't-ibang applications ng sasakyan. You'll be lucky enough if you find the same number parts for Civic and Corolla. :D
    Mar 2003
    Very risky yan. Hihina structural integrity ng rotors mo, pwedeng nag-disintegrate during hard braking. me article dyan sa C magazine.
    EBC drilled rotors na lang...you can get it for 14k...safer ito...
rotor disc(please read)
