Results 1 to 12 of 12
    Attachment 7482
    May oil leak dito, sabi ng mechanico Vtec Repair Kit daw tawag dun. May idea kyo how much it will cost me to buy this Vtec Repair Kit at saan nakakabili? Nagtanong na ako sa mga Auto Supply dito saamin pero wala daw sila nun. TYIA..
    Sep 2004
    Ngayon ko lang narinig yung VTEC repair kit.
    Wala namang oil yung VTEC solenoid ah? Solenoid lang yun, baka yung leak mismo galing sa makina. At hindi na nare-repair ang solenoid, sealed kasi ito. Pag nasira, usually bili na lang ng bago. Sa casa, meron nyan.
    thanks for the reply.. meron ba mga goma ito? ksi sabi pa ng iba pwede din daw i-silicon?
    Sep 2004
    AFAIK, walang goma ang solenoid.
    It is primarily a a loop of wire, often wrapped around a metallic core, which produces a magnetic field (hehe, galing wikipedia yang definition na yan).
    Nagloloko pa VTEC mo? VTEC kasi won't engage when the oil pressure is low, among other factors. Baka yung leak is galing sa engine mismo, tumatapon lang sa solenoid. Gawa ka ng VTEC light to find out! Pero mararamdaman mo din naman kung nag-eengage ang VTEC by the rumble of the engine (for SOHC VTEC-E engines, 2.2k rpm ang engagement point)
    yup ok naman yung Vtec. concern ko lang yung tumatagas na oil. baka nga yung sa engine na mismo. try ko na lang muna i-check.. thanks
    Apr 2006
    same tayo ng problem bro.
    tignan mo yung sa post ko http://tsikot.yehey.com/forums/showt...ighlight=tagas
    sa isang shop na pinagtanungan ko gusto pa ibaba yung engine and ang dami gustong gawin (para siempre majustify yung mahal na singil). ayos na yung sa akin. dinala ko sa kakilala ko talaga na mekaniko. sabi niya meron yang parang rubber na ring na papalitan mo. less than P100. malutong na daw kasi.
    Aug 2006
    emong,
    I had experienced that oil leak on my 96 Civic Vtec. All I did was bought the Vtec o-ring seal (figure 8 rubber seal) worth about P400 sa casa. DIY lang and replacement. You just have to remove the 4 bolts holding VTEC solenoid.
    Apr 2006
    Quote Originally Posted by rasimeon View Post
    emong,
    yep, mukhang siyang number 8 na rubber seal.
    Jul 2005
    Quote Originally Posted by emongedmund View Post
    Attachment 7482
    wala bang malapit na honda casa sa area nyo?
    Nov 2003
    just replace the seal... simple work lang.
    dito sa baguio walang casa ng honda.. pinakamalapit is pangasinan or la union.. but thanks for the advices mga bro.. appreciate it very much.. ill try to buy that oil seal na parang number 8 and replace it pag meron na.. thanks a lot..
    Dec 2004
    If you cant get hold of the seal and you need to repair it asap try using tribond or yung hondabond. Yung parang red paste nasa tube. We did this sa vti ko before and it worked naman.
Oil leak sa Vtec
