Results 1 to 10 of 12
March 23rd, 2007 08:31 AM #1
Attachment 7482
May oil leak dito, sabi ng mechanico Vtec Repair Kit daw tawag dun. May idea kyo how much it will cost me to buy this Vtec Repair Kit at saan nakakabili? Nagtanong na ako sa mga Auto Supply dito saamin pero wala daw sila nun. TYIA..
March 23rd, 2007 08:45 AM #2
Ngayon ko lang narinig yung VTEC repair kit.
Wala namang oil yung VTEC solenoid ah? Solenoid lang yun, baka yung leak mismo galing sa makina. At hindi na nare-repair ang solenoid, sealed kasi ito. Pag nasira, usually bili na lang ng bago. Sa casa, meron nyan.
March 23rd, 2007 08:57 AM #3
thanks for the reply.. meron ba mga goma ito? ksi sabi pa ng iba pwede din daw i-silicon?
March 23rd, 2007 09:54 AM #4
AFAIK, walang goma ang solenoid.
It is primarily a a loop of wire, often wrapped around a metallic core, which produces a magnetic field (hehe, galing wikipedia yang definition na yan).
Nagloloko pa VTEC mo? VTEC kasi won't engage when the oil pressure is low, among other factors. Baka yung leak is galing sa engine mismo, tumatapon lang sa solenoid. Gawa ka ng VTEC light to find out! Pero mararamdaman mo din naman kung nag-eengage ang VTEC by the rumble of the engine (for SOHC VTEC-E engines, 2.2k rpm ang engagement point)
March 23rd, 2007 12:29 PM #5
yup ok naman yung Vtec. concern ko lang yung tumatagas na oil. baka nga yung sa engine na mismo. try ko na lang muna i-check.. thanks
March 23rd, 2007 01:41 PM #6
same tayo ng problem bro.
tignan mo yung sa post ko http://tsikot.yehey.com/forums/showt...ighlight=tagas
sa isang shop na pinagtanungan ko gusto pa ibaba yung engine and ang dami gustong gawin (para siempre majustify yung mahal na singil). ayos na yung sa akin. dinala ko sa kakilala ko talaga na mekaniko. sabi niya meron yang parang rubber na ring na papalitan mo. less than P100. malutong na daw kasi.
- Aug 2006
- 11
March 23rd, 2007 02:09 PM #7emong,
I had experienced that oil leak on my 96 Civic Vtec. All I did was bought the Vtec o-ring seal (figure 8 rubber seal) worth about P400 sa casa. DIY lang and replacement. You just have to remove the 4 bolts holding VTEC solenoid.
March 23rd, 2007 02:15 PM #8
March 23rd, 2007 03:58 PM #9
Tsikot Member Rank 5
- Nov 2003
- 3,848
Ongoing problem pa din Pala ito even among euro cars ...
Takata Airbag Problems
