Results 1 to 18 of 18
    Apr 2005
    Guys who DIY their oil change, how do you dispose of the used engine oil? I feel guilty dumping it in the sewers.
    I do it myself because I want every drop of the old oil out, so i normally do it at night and let the oil drain away the whole evening. To those who want to try this, just be careful not to forget you have no oil that night and keep that car in the innermost part of your garage just in case
    Thanks
    edit: I now have several used-oil gallons around the house, and the wifey's not very happy with it
    you shouldn't dump it!
    Just bring it to your nearest gas station and dump it in their canisters. They'll send it back to the plant to make grease and other lubes.
    Apr 2005
    thanks, I suppose they wont charge me or anything right?
    Jun 2005
    afaik binibili ng bote-dyaryo yan...
    Just give it to the gas station. Matutuwa pa sila sa iyo because they sell used oil to the recycler.
    May 2005
    Quote Originally Posted by OTEP
    ..tama si sir Otep..last time ako nag change oil doon nag ask muna ako sa Shell baler ..binigyan pa ako ng small container (suki kasi ako doon)..then after ibinalik ko kasama na ang langis
    i dump mine sa bakanteng lote na puro itlog ng lamok. (mga thirce na)
    Its bad I know.
    Kaya sa mga small talyer na lang ako. P120 labor small pice to pay to be called responsible
    I remember one time yung neighbor tinapon during baha, lahat ng wall ng mga gate nahawaan ng grasa
    Acheche!!!
  8. #8
    Be responsible mga peeps, lahat ng tinapon babalik din sa iyo di ba? Sa gas stations na lang ibigay para proper disposal, pero dito sa amin sa laguna (sta. rosa) di tinatanggap pag di ka sa kanila papachange oil.
    kung tinapon sa lupa babalik din sa water system at drains... not good.
    Jun 2005
    By giving your used oil it to the service station, dapat nga bayaran ka pa nila. You even help protect the environment.
    Nov 2003
    bring it to us. we'll take it
    Apr 2005
    Ayus yan Speedy = ), neways dinala ko na sa suking gas station and they gladly accepted naman. So tuloy lang ang DIY ko hehe
    Apr 2005
    madali lang ba mag-diy change oil? balak ko sana...para makatipid ng konti...takot lang ako baka hindi ko mapalitan ng maayos yung oil filter...i read somewhere na hand tight lang ok na, pati na rin sa plugs. tama po ba?
    Apr 2005
    Madali lang. Ako I just use a semi-wet cloth to tighen the filter but I use wrench for the plugs. There are tools which you can use to tighen the filters if you want.
    maverick sa paglalagay ng oil filter pwede ka rin gumamit ng sandpaper para di dumulas...
    sa plugs naman tantiyahan na rin kadalasan lalo na kung wala kang torque wrench...alam mo naman siguro pakiramdam ng di maluwag at di sobrang higpit (yung point na masisira na ipin/grooves ng spark plugs)...
    Apr 2005
    anonimous & chieffy, tnx for ur replies. would it be advisable to invest in an alligator jack & jack stands? any suggestions? tnx for d help!
    just take it to your suking gas station. Mura lang naman magpa change oil. No hassles, no environmental problem. baka si speedyfix may pa merienda for your used oils. ;)
    Nov 2003
    hand tighten lang yung oil filter. while the car is still on stands, paandarin nyo sandali... around 5-10 mins para sure kayo walang leaks
oil change DIY
