Results 1 to 11 of 11
    Jan 2011
    sino po meron OBD I scanner dito sa Lipa City or Tanauan Batangas? need ko pa check oto ko , labas check engine lights
    Nov 2011
    Quote Originally Posted by slowrockmusic View Post
    AFIK, there is no OBD 1 scanner, you simply have to look for the diagnostics wire and short it out, and the check engine will blink and from there you can get the code, try google and youtube for more info
    Sep 2012
    Sent you a private message sa number ni John na taga Lipa... OBD 2 scanner gamit nya pero meron din sya connector for OBD 1. Confirm mo na lang sa kanya kung meron sya ng para sa sasakayan mo
    Jan 2011
    Quote Originally Posted by jodski View Post
    sir mag kano kaya mag pa scan? hinde ko kasi madala don sa lipa city kasi namamatay makina at nag misfire,dito pa ako tanauan batangas ano cel number nya?
    Jan 2011
    Quote Originally Posted by jresperanza View Post
    hinde po sya nag blink eh naka steady lang CEL then engine shut off
    Sep 2012
    Nag send ako ulit ng private message sir... sya na lang tanungin mo sa price hindi ko kasi kabisado...
    Oct 2011
    sir ano make model car mo?
    Jan 2011
    Quote Originally Posted by Aracad665 View Post
    Mitsu Galant MPI 1989 EFI engine baka alam nyo sir kung saan banda naka kabit ang camshaft sensor at crank shaft sensor nito, hinde ko kasi makita
    Sep 2012
    Bro pachek mo nalang kay J&R tanauan or san roque ang alam ko may scantool sila
    Jan 2011
    Quote Originally Posted by Batangenyo View Post
    salamat pre sa san roque ba
    J & R
    tanggalin mo timing cover para makita mo cam sensor, yung crank sensor parang kailangan mo din tanggalin yun crankshaft damper pulley
OBD I scanner along Batangas
