Results 11 to 20 of 20
- Nov 2005
- 824
September 16th, 2015 12:18 PM #11
September 16th, 2015 12:20 PM #12
Sa normal air lang din ako due to the following reasons :
1. Mas may peace of mind ako in-case lumambot gulong ko sa malayong lugar na walang malapit na vulcanizing shop.
2. Mas matipid kasi bumili na lang ako ng electronic air pump sa Ace around 400 ata (20% discount). Mag 2 years na at functional pa rin naman.
3. Ok na sakin to kasi weekly naman ako magcheck ng tire pressure at walang malapit samin na nitrogen refilling station.
- 52,731
- 52,731
September 16th, 2015 12:25 PM #14- - - - - - - - - - - - - - - - - - - - - -
1. not a problem. nitrogen and air are fully exchangeable.
2. i got the more expensive one.. 1800 to 2000 bucks. it's really faster, and... you can use it more than once or thrice, longer working time too, and still maintain its efficiency. my experience with those small/cheaper ones.. they get hot faster, and they lose efficiency with multiple use.
- Nov 2005
- 824
September 16th, 2015 12:31 PM #15
September 16th, 2015 12:38 PM #16
Agree dr.d that it gets hot quite quick, 10 minutes lang ata yung recommended continuous use. Siguro kung dumami na tsikot ko mag invest na ko sa more expensive pump.
I call it an investment since DIY na yung pag rerefill ko ng air at di ko na need mag tip/bayad sa suking vulcanizing or gasoline boy. Yung pa lima-limang piso or higher pag kinompyut ko sa isang tao eh daan-daan din.
Pwede rin ako magrefill anytime at anwhere kaya less abala at gas expense.
- 52,731
September 16th, 2015 12:41 PM #17
September 16th, 2015 02:10 PM #18
this not so big tire shop nearby face lifted his shop. invested a lifter and a nitrogen air pump. kaso mukhang nilalangaw yun pump nya, 100petot/tire.
September 16th, 2015 02:49 PM #19
- Oct 2014
- 1
October 8th, 2015 12:00 AM #20las pinas: sm center las pinas - sa tirecenter
initial nitrogen fill: Php 50 per tire
top-up: Free
hope this helps!
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
