Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Feb 2006
    Guys, this may be a stupid question for some of you, but I just want to know the difference. I have a hand-me-down Revo and I'm not sure if the timing belt has been changed. The mileage is more than 100,000km and I have no idea. I know I had it serviced before because the fan belt (at least that's what I know it's called) was changed.
    Please enlighted this newbie here. Thanks.
    Sep 2004
    Timing belt - part of an internal combustion engine that controls the timing of the engine's valves. Such belts are used for power transmission or to interchange rotary motion and linear motion, where either high loads or maintaining a specific drive ratio are important.
    Fan belt - the traditional term for what today is called a drive belt. Drive belts are made of reinforced, high-tensile strength cords and synthetic rubber. Drive belts provide power to engine-mounted accessories like the power steering pump, air conditioning compressor, mechanical cooling fan and air injection pump.
  3. #3
    timing belt-nasaloob ng cover, nakapalupot sa valve-cam gear and shaft, crank gear and shaft,oil pump and injector pump(kung old diesel) etc..pinapalitan every 60-100 thousand kms
    fanbelt-nakikita mo..usually, main pulley, alternator...(at kung meron) aircon, powersteering, supercharger..pinapalitan kung may cracks and kung masyado na maluwag...
    Feb 2006
    you're right,BOGEYMAN
    Dec 2003
    fan belt - if it breaks, you're screwed
    timing belt - if it breaks, your double screwed
    Feb 2006
    mas mainam kung timing chain ang gamit mo kaysa timing belt, usually u can use d timing belt until 100k miles b4 changing but 4 safety change when u reach 60k miles
    Oct 2005
    Quote Originally Posted by e36bmw
    i agree...belts are more susceptble to slippage at mas matibay ang mga chain kesa belt...pero...sa pagkakaalam ko, maiingay ang mga cars na equipped with timing chains at bihira na ang mga cars na gumagamit nito...tama ba?
    May 2005
    Timing Belts:
    -nasa loob ng engine
    -nakaconnect sa gears
    -flat na belt pero toothed belt
    Fan Belts:-nasa labas ng engine
    -nakaconnect sa Pulley
    -V-shape sia or V-belts
    pero may design din na may parang toothed belt or V ribbed belts yata iyon
    Aug 2004
    BTW, on newer front wheel drive cars, it's more accurate to call fan belts accessory belts, because they power the accessories and are not directly connected to the fan.
    And no, you're not screwed if a fan belt gives way, you just have to get to the service station before your car overheats (water pump won't turn) or your battery dies (no alternator). Of course, this all depends on which belt breaks, because many modern economy cars have two belts, if the belt that breaks only connects to the AC and power steering... you'll live.
    But if your timing belt goes, yes, you are screwed...
    you're more screwed when the timing belt snaps, then you try to start your car several times....
    Quote Originally Posted by ssaloon
    OT: yup, it happened to me back in '02,.. meron na talagang tunog, so I thought ok pa ibiyahe,. so paglabas ng village, ayuuun, spontaneously the engine just shuted off,.. it was towed to MMC Pasig/Marikina,.sobrang hassle grabe. Luckily, hindi nasira yung mga internals, tsk tsk!
    Ang Nissan Frontier ba naka-timing belt or timing chain?
    May 2004
    2345mph; i think timing chain.
    Feb 2006
    umzzzzz.. di maingay ang mga cars na gumagamit ng timing chain, bmw used timing chain pero di maingay
    Nov 2003
    it's slightly more noisy than one with a belt but hardly noticable.
    ask ko lang kong kaylan ba dapat magpalit ng timing chain??? thanks
    May 2004
    baka timing belt. di kasi pinapalitan timing chain(maintenance wise).
    Aug 2004
    The chains are supposed to last longer than the engine, but it's a good idea to have the tensioners (tama ba yun?) checked every 50-60,000 km to be sure.
    Although a timing chain failure is very rare, having the tensioners loosen is not unheard of.
    Feb 2006
    niky pde din ba na timing chain ilagay kahit sa anong car? iba ba yung tensioner na gagamitin pag nagpalit ka ng chain instead of belt?
  20. #20
    alam ko pag belt na ang makina di na pwede i-convert sa chain...unless, palit ka ng engine na may chani na talaga...
    ang isa pang nga pangit sa belt is prone sa slippage, that is kung sira/leaky ang oilseals ng cam/crank shaft mo...nangyari sa maxima ko, 3x nakapagpalit kasi na-overlook ung oil seal sa sa crank/cam shafts,e....
    alam ko sa fan belt masmaganda ung v-shaped na grooved kaysa sa solid v-shape...how true is this? kasamaang palad, maxima ko iba ang fan belt, not the v-shape but the flat one..
    nga pala, mostly older engines have multiple fanbelts...than sa bago na 1 or 2..bibihira na ang 3 or more...
Newbie here: What is the difference between a timing belt and a fan belt?
