Results 1 to 5 of 5
December 16th, 2006 11:53 AM #1
hehe makikigather alng po ng mga info...lately before my car experience overheated so the result is nagsingaw ung sa cyl gasket nia.so water and oil on my rad are mix.so pinagawa ko ung problem na un resurface nd head at palit ng gasket. dbah isang source ng white smoke is singaw ng cyl gasket. so nd man io cguro ang problem ng car. kasina tapos na .then others say nman bka nd natutune up.last month na tune up ito.and bihira koman dingamitin kasi may motor din me.then pina check kosa CarX. sabi nila basta naka exp. na ng overheat ang car bka ung sa may piston ring nya daw..Can sumbody agree rith the last observation nila on my car. and if ever nman mga magkano nman kaya ang pede magastos kung sa may bandang piston ring ang tatrabahuhin and wat kind of work.. or bka may iba pang alternatives para mawala ung white smoke ..impossible ba ung sa tv na na commercial na lagay mo daw sa makina mo then ung smoke mawawala nah? and anongtawag dun thanks im a newbie raider kasi konti lang knowledge kosa car .THNKS IN ADVANCE FELLOW TSIKSTERS.. AY TSIKOTERS PALA ....
"burn rubber , not yah soul"
December 17th, 2006 05:18 PM #2
dyeth28,
Easy on the text messaging syle posting. You'll find out that if you express yourself clearly mabilis ang reply ng queries mo. Have a nice day.
- Nov 2006
- 299
December 17th, 2006 05:34 PM #3[QUOTE=dyeth28;718888]hehe makikigather alng po ng mga info...lately before my car experience overheated so the result is nagsingaw ung sa cyl gasket nia.so water and oil on my rad are mix.so pinagawa ko ung problem na un resurface nd head at palit ng gasket. dbah isang source ng white smoke is singaw ng cyl gasket. so nd man io cguro ang problem ng car. kasina tapos na .then others say nman bka nd natutune up.last month na tune up ito.and bihira koman dingamitin kasi may motor din me.then pina check kosa CarX. sabi nila basta naka exp. na ng overheat ang car bka ung sa may piston ring nya daw..Can sumbody agree rith the last observation nila on my car. and if ever nman mga magkano nman kaya ang pede magastos kung sa may bandang piston ring ang tatrabahuhin and wat kind of work.. or bka may iba pang alternatives para mawala ung white smoke ..impossible ba ung sa tv na na commercial na lagay mo daw sa makina mo then ung smoke mawawala nah? and anongtawag dun thanks im a newbie raider kasi konti lang knowledge kosa car .THNKS IN ADVANCE FELLOW TSIKSTERS.. AY TSIKOTERS PALA ....
"burn rubber , not yah soul"[/QUOTE
ayusin mo mga words mo,di ko maintindihan,di naman din ako bagets na tulad mo na mahilig sa short texting,,no offend,..
December 17th, 2006 06:05 PM #4
hehehe...ayan na duling na si Dennis Powell...mag kaedad siguro kami nito. ;)
dyeth28,
You can put numbers nalang so we can see in chronological order the things that were done in you engine.
December 19th, 2006 12:12 PM #5
Hehe Oo Nga Nuh , Nasanay Kasi Ako Sa Cellphone Kaya Pati Dito Sa Forum Nadadala ko..Hehe Pasenxia Na Mga Guys.. O Sige Ito Kasi Ang Problem There Is A Massive White Smoke Emmiting From My Tail Pipe.. My Car Experience Overheat Dati.. So As Simple As This When You Overheat Siyempre The 1st Fact Na Papasok Sa Mind Mo Is Ung Cyl. Gasket. So Pinawork Ko Na . Got The Cyl. Gasket Replace , The Cyl. Head To be Resurface. Then After Work Dun Na Lumabas Yung Grabeng Usok. Pero At Least Hindi Black ang Lumalabas (Hehehe).
Here Are The Alternative Facts. Na Nagather ko
1.According To Some 1 In This Forum . Baka Hindi daw natutune up. Kaya there is The Possibility na mag Emmit Yung pipe kong White Smoke.
2. Others Said , Ayun Nga Baka Sa Cyl. Gasket . Water and Oil are Mixing So White SMOKE In The Pipe is A Water that is Steam.
3.My Mechanic Said An Overheat Exp. May Lead your Piston ba or Piston Ring Not to Compress Properly?? Basta Yun na yun Something Related On The Piston/Piston Ring Term...
Ngayon ang sakin is Does This 3 Facts is Sure or Maybe Meron pang Iba dyan na idea para hindi nman aksaya sa time , effort and money.. And Ano ba ang mapapayo nio? Does This Work Is Got to Do With TOP OH. And what items should i list in my inventory to be purchased and an Estimated Amount... Or Baka naman pede pa toh madaan sa Parang OIL na Minimix yata sa Engine Oil or Gasoline para mawala or ma Minimize yung Smoke It has once advertise on TV kaso hindi ko alam kugn anong exact term sa items na yun? baka may alam kayu and Does it effectively works..Hahaha. e2 lang kasiung malakign problem ko yung white smoke nakakahiya kasi . Natatawa ako kahapon pag Fill ko ng gasoline and pag start kong car natakot yung mga tao around The Gasoline Station. Kala nila sasabog yung car. parang Mt. Pinatubo yung buga nang white Smoke nakakhiya heheh.
Oh wala ng reklamo ha Inayus kona ung Message ko..Thanks Fafa Powell
Automatic po Sir
