Results 1 to 5 of 5
    hehehe...ayan na duling na si Dennis Powell...mag kaedad siguro kami nito. ;)
    dyeth28,
    You can put numbers nalang so we can see in chronological order the things that were done in you engine.
    Hehe Oo Nga Nuh , Nasanay Kasi Ako Sa Cellphone Kaya Pati Dito Sa Forum Nadadala ko..Hehe Pasenxia Na Mga Guys.. O Sige Ito Kasi Ang Problem There Is A Massive White Smoke Emmiting From My Tail Pipe.. My Car Experience Overheat Dati.. So As Simple As This When You Overheat Siyempre The 1st Fact Na Papasok Sa Mind Mo Is Ung Cyl. Gasket. So Pinawork Ko Na . Got The Cyl. Gasket Replace , The Cyl. Head To be Resurface. Then After Work Dun Na Lumabas Yung Grabeng Usok. Pero At Least Hindi Black ang Lumalabas (Hehehe).
    Here Are The Alternative Facts. Na Nagather ko
    1.According To Some 1 In This Forum . Baka Hindi daw natutune up. Kaya there is The Possibility na mag Emmit Yung pipe kong White Smoke.
    2. Others Said , Ayun Nga Baka Sa Cyl. Gasket . Water and Oil are Mixing So White SMOKE In The Pipe is A Water that is Steam.
    3.My Mechanic Said An Overheat Exp. May Lead your Piston ba or Piston Ring Not to Compress Properly?? Basta Yun na yun Something Related On The Piston/Piston Ring Term...
    Ngayon ang sakin is Does This 3 Facts is Sure or Maybe Meron pang Iba dyan na idea para hindi nman aksaya sa time , effort and money.. And Ano ba ang mapapayo nio? Does This Work Is Got to Do With TOP OH. And what items should i list in my inventory to be purchased and an Estimated Amount... Or Baka naman pede pa toh madaan sa Parang OIL na Minimix yata sa Engine Oil or Gasoline para mawala or ma Minimize yung Smoke It has once advertise on TV kaso hindi ko alam kugn anong exact term sa items na yun? baka may alam kayu and Does it effectively works..Hahaha. e2 lang kasiung malakign problem ko yung white smoke nakakahiya kasi . Natatawa ako kahapon pag Fill ko ng gasoline and pag start kong car natakot yung mga tao around The Gasoline Station. Kala nila sasabog yung car. parang Mt. Pinatubo yung buga nang white Smoke nakakhiya heheh.
    Oh wala ng reklamo ha Inayus kona ung Message ko..Thanks Fafa Powell
need other advices... (white smoke problem)
