hi guys! need your help...ano po ba ang magandang engine setup sa kotse ko.. my car is 96 civic vti a/t ano po ba magandang engine setup para dito to add more power...thanks
how much are you willing to spend?
you can go IHE, custom turbo, or engine swap. it all depends on your budget and preference.
mga sir paano kung yung budget is 30k ano po ba maganda pagkasyahin dun for a 96 civic vti a/t?
Assuming you already have better wheels, if you want "mucho-power" for 30K, you can try your luck at getting a 2nd hand nitrous oxide system. Its good enough to add 30hp to 50hp to your car. This is much more than other typical bolt-ons will give you for the same money.
Just save up some money to upgrade your brake pads too.![]()
thaks for the advise sir...magkano po kaya ang magagastos ko if IHE lang po ang upgrade ko kasi gusto ko lang po yung for everyday driving lang po pero may sipa:naughty2: advisable po ba yun IHE upgrades for a car with an a/t tranny??
you might lose some torque given that your car is an A/T when you upgrade you exhaust diameter and install a freeflow muffler.
with that budget i'd just go for a set of springs, good brake pads and a filter, kung may tira mags nalang... short of turbo kasi you really won't get much more power from a matic.
mga sir I was thinking of an engine swap with a B16a or a B16b?? ano po sa tingin nyo malaki po ba ang madadagdag na power?? magkano po ang kailangan ko with this project?? thanks
