Results 1 to 20 of 20
    May 2017
    Bka naman po may nakapag try na sa inyu mag tanggal ng mirror sa side mirror ng toyota corolla bigbody.Turuan nyo nman po ako ng tamang pagtatangal, wla kc ako makita sa you tube.TIA
    Sep 2004
    Power side mirrors ba? May dalawa o tatlong bolt sa loob na side ng pinto, 10mm iirc. Just pull the covers out.
    Parang ito sa pic, different vehicle pero same concept.
    Sent from my SM-G930F using Tapatalk
    May 2017
    Quote Originally Posted by L1quid View Post
    Sir thanks sa effort.pero ung salamin po mismo ng sidemirror ung gusto tangalin or cguro ung glass nia.thanks
    Sep 2004
    Ah, hahaha! Kung stock side mirrors yan, madali lang yan, tutungkabin mo lang, sa dulo mo kunin, sa far side.
    sinusungkit lang yan ng magnanakaw.
    May 2017
    stock pa naman xa.nag try ako na gamitan ng screw pero ayaw nia.ntatakot pa ako pwersahin bka kc mabasag, meron cgurong tamang position ng pag titiklap..
    May 2017
    Quote Originally Posted by robot.sonic View Post
    na isip ko nga yun eh.pano kaya nila binbkals to hehe
    Sep 2004
    Naka clip lang yan bro. Eto pang ibang kotse uli pero parehas lang naman yan.
    https://youtu.be/0ezqnEKIA5A
    bakit mo pala gusto tuklapin?
    May 2017
    hindi kc gumagana ung up and down ng mirror nia..palagay ko nag stock lang cguro ung motor nia..
    May 2017
    thanks, cge po try ko
    May 2017
    try ko ule maya,sana hindi sya mabasag hahaha..thanks
    May 2017
    Nagtry ako ayaw tlaga eh.baka meron pa po jan nka experience mismong bigbody na side mirror
    Quote Originally Posted by wakpng1986 View Post
    if you are not the first owner of this car,
    is it possible, the previous owner used glue, to ensure his mirrors won't fall prey to the "sikwat gang" ?
    years ago, there was this epidemic of sikwat mirror thievery. we saw all sorts of gadgets, to foil the thieves. one of them, was superglue.
    May 2017
    ahh baka nga, kaya pala khit anong tungkab ko hindi sya ma alis.pano na kya un doc..may idea po ba kayu kung pano inaalis pag nka glue?
    baka puedeng dukutin yung motor from the inside?
    if the angle is right, keep on using until it until it needs replacement.
    if the angle is wrong and is near-useless because of that,
    baka puedeng pilitin? bahala na kung may mabasag.
    hanap ka ng replacement assembly, in case na masira sa pag pinilit.
    May 2017
    ok pa naman doc, sakto lang yung angle nya pag nagdrdrive ako,pero pag papark yung tipong halos sagad sa gutter hindi ko magawa kc nga hindi na sya tumutungo..hehe.anyway maraming salamat sa inyu..
    assume it's an XL you are driving.
    May 2017
    Dr. D ok na hindi ko problema ung side mirror ko..kc binenta ko na hehe
Need help for my side mirror ae 101
