Bka naman po may nakapag try na sa inyu mag tanggal ng mirror sa side mirror ng toyota corolla bigbody.Turuan nyo nman po ako ng tamang pagtatangal, wla kc ako makita sa you tube.TIA
Power side mirrors ba? May dalawa o tatlong bolt sa loob na side ng pinto, 10mm iirc. Just pull the covers out.
Parang ito sa pic, different vehicle pero same concept.
Sent from my SM-G930F using Tapatalk
Ah, hahaha! Kung stock side mirrors yan, madali lang yan, tutungkabin mo lang, sa dulo mo kunin, sa far side.
Naka clip lang yan bro. Eto pang ibang kotse uli pero parehas lang naman yan.
https://youtu.be/0ezqnEKIA5A
Nagtry ako ayaw tlaga eh.baka meron pa po jan nka experience mismong bigbody na side mirror
if you are not the first owner of this car,
is it possible, the previous owner used glue, to ensure his mirrors won't fall prey to the "sikwat gang" ?
years ago, there was this epidemic of sikwat mirror thievery. we saw all sorts of gadgets, to foil the thieves. one of them, was superglue.
baka puedeng dukutin yung motor from the inside?
if the angle is right, keep on using until it until it needs replacement.
if the angle is wrong and is near-useless because of that,
baka puedeng pilitin? bahala na kung may mabasag.
hanap ka ng replacement assembly, in case na masira sa pag pinilit.
