Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
    Apr 2004
    palabasin mo na lang ng auto yun mga tao pagmalulubak... hehehehehe joke! palitan mo mags mo and gulong... baka naman kasi sobrang low profile...
    Jul 2004
    Nitrogen refilling of shock at Zee Shop is P600 per shock with 1 year warranty. Restoring tie rod, ball joint, pitman arm, etc through polymer injection varies from 250 to 300 with 15Km warranty. Balak ko sana palitan na yun sirang OEM shock ko sa Pajero (with adjustable damping setting) with Bilstein pero masyado mahal (6500++/piece). I have zee restore it for 1400 (2 front shocks) including labor. Ok naman gumana na uli yun 3mode damping setting. In doing the nitro refilling zee will weld a refilling nut on your shock housing. It took two hours job for my Pajero. Worth a try, Toti (shop owner) will advise you if its worth to restore your shock or not. He has several racing clients. Eto yun contact number: 7248309, 09174331964.
    mga 2500 per piece sa harap, 1500 naman per piece sa rear.
    Quote Originally Posted by banjo123
    Need help po. Im using merwede 1.5 drop with 16 size rota quake mags and di na ako natutuwa sa tagtag ng oto ko...napa check ko naman yung shocks ok pa. Im planning to change my spring kahit close to stock lang yung feeling...nagrereklamo na kasi magina ko everytime nalulubak kami talagang ramdam na ramdam yung tagtag...na mimiss ko na tuloy yung stock ride. Patulong naman how to improve my ride. Better to change my spring or change size mg mags or palitan pareho?
    if you still want that "porma" look, change your mags from 16 inch to 15 inch and use 55 series or 60 series tires.
    if you really want to near to stock ride quality, you will probably have to settle with 14inch mags and 55 or 60 series tires.
    Nov 2006
    mga sir, can u help me too. sensya n if d2 ako tanong ha i dont know kasi wer to ask. di p talaga maganda ang lowering springs? meron kasi ako mabibilan d2 s taiwan ng coilover pro d ko alam if ok kasi mga taiwan made lang. mas ok p dinkaya to kesa s mga branded n springs? hope u can help wirh dis. thanks
Need help...di na ko natutuwa sa ride ko
