Results 1 to 6 of 6
- Aug 2005
- 28
September 21st, 2005 07:46 PM #1Need help from the experts.
Weird, pero bakit nangyayari na naiiba ang timing ng ride ko when you rev it up or go on highspeed driving?
Napa tune up ko na and the timing was adjusted to 10 then when I went to Pampanga hataw ako 100kph to 140 kph. Pag dating ko dun tumotope na pag arangkada and then maingay sya. I had the timing read and it was way past 10 degrees.
I experienced this twice already.
Hmmm... what could be wrong?
The subject ride is a 1991 corolla 1.6.
September 21st, 2005 07:59 PM #2
baka hindi nahigpitan yung adjustment ng timing kaya gumalaw? or worse, baka tumalon ang timing belt?
September 21st, 2005 08:09 PM #3
nyaiks, you better get it checked, kita naman kahit valve cover palang tinanggal, baka mali ang higpit ng tensioner at tumatalon belt mo. Matsempohan ka tukod valves mo nyan, para kadin naputulan ng belt.
- Aug 2005
- 28
September 21st, 2005 08:23 PM #4Originally Posted by theveed
Thanks Sir Yebo and Sir Theveed.
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 22nd, 2005 11:23 AM #5yup possible na tumatalon yan... delikado nga and it should be checked agad.
- Sep 2005
- 103
September 22nd, 2005 01:01 PM #6May advancer ba un? baka sira?
does advancer has to do something with the timing?
wild guess lang po!
Monk-owned R53
