Results 11 to 20 of 23
October 9th, 2006 12:58 PM #11
I also wanted to add... there is that method we call "dollar test"; you take a dollar (doesn't necesarrily have to be a "$" bill, but you get the idea) and put it on top of the muffler tip, half of it on lying on top of the muffler, and the other half hanging within the hole of the muffler. Have someone turn the car on, if the dollar gets sucked and went inside the muffler, you have a valve leak... otherwise the valves are ok... I don't know if this is to all cars, but it's pretty popular to many different car owners and seems to work pretty accurately...
- Oct 2006
- 32
- Sep 2006
- 4
October 18th, 2006 04:35 PM #13
October 18th, 2006 04:41 PM #15
- Oct 2006
- 32
October 18th, 2006 10:24 PM #17
my guess is that the valve guides and valve seals of one or more exhaust valves are leaking oil down to the exhaust manifold. kaya meron oil sa exhaust. this could be caused by a bent valve guide bore resulting from the piston hitting the valve when the timing belt broke.
- Oct 2006
- 32
October 18th, 2006 10:54 PM #18*yebo
thanks sir, sir anu po bang pyesa to? ito daw po yun pinalitan eh ska mga belt etc, nahagilap ko lang kanina
ang pinagtataka ko lang po parang magkakaiba..Last edited by renfox; October 18th, 2006 at 11:02 PM. Reason: insert image
October 19th, 2006 06:59 PM #19
yung malaking diameter ay intake valves ung mas maliit ay exhaust valves
high idle RPM at engine start
