Results 51 to 56 of 56
November 9th, 2006 06:27 PM #51
November 9th, 2006 06:45 PM #52
A lack of lock on the right? Sounds downright strange, unless there's a problem of mismatched parts... maybe they did a cut and weld instead of a full-on conversion with LHD parts?
Still, it's too early to tell. Keep us updated, GS, and glad you're safe!
November 9th, 2006 08:33 PM #53
di po siguro malinaw meaning ko:
di lang po dahil sa converted kaya nagkaganun, i wanna make it clear na maaring may ibang factors pang involve....
kung may mali sa conversion, sana ramdam agad yun since bought, si sir GS pa... ko dun sa delica ko, mali ang conversion, ramdam sa ikot ng manibela, even if standing (maganit sa one-side, and rattles, at di mag-permanent ang alignment/camber)..i know na to detect kasi 6 years na ako nagddrive at nagtitingin-tingin ng converted rides...and i'm still willing to buy a converted ride even still i know na may risks and hard labor involve....
pero totoo yun bad weather+snow-tires, ganun talaga ang lock-up in a wet-road, nangyari na sa akin yan sa nissan maxima ko, 120kph on EDSA, umikot ako dun, buti walang kasunod...although not on snow tires(wala talagang bagong nabibili nun sa atin), pero ganun nangyari.as explained ni sir niky, hydroplaned.
kaya sorry kung point out ko agad ung snow tires, kasi snow tires are not designed for high speed wet roads..
lets be glad minor lang damage, ung lang po.
kaya i suggest, kung wala kang tyaga sa sasakyan, bago or well-maintained kunin mo.. pero ako, matyaga at willing to learn sa sasakyan at limited lang budget, ok na sa akin converted rides.Last edited by alwayz_yummy; November 9th, 2006 at 08:37 PM.
Tsikot Member Rank 4
- Oct 2004
- 2,315
November 9th, 2006 09:06 PM #54ang theory ko din is converted like m2's. Or hydroplaned. Yun mga wrc drivers kasi nakikita ko pag nagdrive kumakabig sa left pero sa right papunta. Baka ganun nangyari?
November 11th, 2006 01:05 PM #55
must be a faulty conversion process or faulty parts used. i share the same theory with M2 also.
November 11th, 2006 02:06 PM #56
Pumunta na ako sa PRENS yesterday morning.Right rear is locked when the handbrake is release.
Palit ng brake pad,liha ng disc atbp. cost around 2,180.Hindi ko napalitan ang front brake pad dahil walang magmatch na brake pad.
Bendix ang brake pad ko ngayon sa likod kaso VISIN ang front brake pad ko
Sino may alam kung saan nakakabili ng brake pad na pang EK9 for front?
Thanks.
Xiaomi E-Car
