Results 11 to 18 of 18
November 17th, 2005 10:54 PM #11
fuel filter can be replaced in just under an hour. fuel pump mas matrabaho na. pagawa mo nalang sa shop kung pump.
November 17th, 2005 10:59 PM #12
oo sir, most probably fuel system. a few months ago, i hthought something bad happened to my faithful old Civic. initially i panicked 'cause the throttle seem to be unruly. gusto laging mabilis! :D anyways, i referred to the service manual, and thought that the ecu have gone bad (which is i felt bad since i thought if the ecu is busted, then i should have gotten a ecu upgrade). the culprit: bad throttle body.
i have it cleaned with Honda. Voila, it runs as smooth as ever.
still i felt bad about that ecu upgrade. i thought i would a new one. :D
November 18th, 2005 11:17 AM #13
*Bluebimmer: thanks! sana nga fuel filter lang. will know tomorrow when i bring it to autovec.
*chris_d, mazdamazda, theveed: thanks for your inputs as well
*ian_rex: thanks! pwede naman mag-upgrade ECU kahit di pa sira di ba? idahilan mo na lang na 'preventive measure' sa department of budget, kung meron man...hehehe
November 18th, 2005 11:24 AM #14
Hmm the fact that it occurs often pag nakaincline ka makes me think na fuel filter talaga, baka blocked na yung filter and kung nakaangle yung car di na nakakadaan yung fuel sa ibang areas ng filter.
I'd change this asap before it creates more havoc my friend.
November 18th, 2005 12:13 PM #15
thanks! will have the filter changed tomorrow. then observe ko na lang for a while.
November 21st, 2005 10:05 AM #16
Update lang guys. I was able to have my fuel filter changed last Saturday. Sabi nung mechanic, medyo barado na nga raw. After changing, i observed the car and mukhang ok naman sya so far. I braved the same incline yesterday in Boni(at least pag Sunday konti lang umaakyat). So far, di na naman ako namatayan ng engine. Will observe the car for the next few days. Hopefully, yon na nga ang problema and not the fuel pump.
Thanks again to everyone!
November 21st, 2005 11:13 AM #17
Sa sentra namin ganyan din dati, biglang mamamatay engine, tapos hirap mag start. Pag-umandar na dapat di bababa sa 1000rpm or else patay ulit. Pinalitan ung fuel filter ganun pa din. Un pala sira na distributor
November 29th, 2005 03:12 PM #18Originally Posted by swordsman
Xiaomi E-Car
