morning starting, bakit matagal mag start, mabilis naman ang ikot ng starter, pero pag mainit naman ang makina 1 click naman, glow plugs ba? or Fuel Filter? L300 Diesel Van..
Glow plug siguro. Mas may affect ito kung cold starts.
yah that's true, glow plugs, Busted All 4, kaya bumili ako ng 4 pcs. NEC brand. ok ba to.. nasira pa yung Starter ko kaka Start... hindi umikot, ano kaya ang sira? kaya tulak nalang...he eheh
Glow plugs are usually the prime suspect. I would always recommend OEM for that item but since you have purchased already, then good luck with the NEC units.
Also check the glow plug relay bolted onto the battery terminal. If it's lose or corroded, it won't have enough juice.
ok na yung VAN ko, the culprit is the Glow Plugs, so I changed all 4, and the Starter checked also, so my VAN its already OK again, 1 click to start.. thanx to all your comments!..
dapat ba palit ng sabay sabay ang Glow plugs?
sayang kasi kung isa lang ang busted
dapat...kasi di na pare pareho ang time to glow pag hinalo na ang luma sa bagong plugs...pero...pero ;)
